Alpine Wiring Question
Old Jul 18, 2006 | 12:23 PM
depechek's Avatar
Default Alpine Wiring Question
On the Alpine's instructions its stating that I need to plug the power wire directly into the battery. So does this mean I cannot splice the power wire from the alpine harness to the aftermarket honda harness? I included some pics to clarify.
Do I splice these two together (yellow wires) like I would with other installs or is Alpine telling me not to do this?
Aftermarket Honda harness (for my Accord not S2k)
Alpine harness
Old Jul 18, 2006 | 01:53 PM
oth's Avatar
oth
your alpine is more powerful than most OEM headunits, so alpine is
concerned that you can't safely draw sufficient current through
the factory wire, which is why they have you hook it directly to
the battery.
if you're using an external amp and can turn off the internal amp,
I think you'd be fine with the factory wire, but otherwise I'd probably
follow their advice and connect it directly to the battery.
Old Jul 18, 2006 | 02:14 PM
smurf2k's Avatar
run a line from battery, to the back of the HU, splice it into the thick yellow wire that goes into the alpine
Old Jul 18, 2006 | 03:21 PM
depechek's Avatar
ok I just spliced the wires since I really don't listen that loud. Unfortunately, I do not have a ext amp and the HU is powering the 4 OEM speakers. I am just going to wire everything through the honda harness. Thanks for your help guys.
Old Jul 18, 2006 | 09:51 PM
smurf2k's Avatar
if you have a multimeter you can measure resistance of the speaker, derive appropriate output voltage (to speaker) where power falls below 20w... note volume level... and if u generally play below that volume it should be okay
DuCKy!
Jun 21, 2015 06:24 PM
TookayS2K
Feb 4, 2009 07:16 AM
depechek
Jul 18, 2006 03:19 PM
CarmenOhio
Mar 20, 2006 05:18 AM
jwa4378
Jun 12, 2005 03:57 PM
