Upgrading from an Alpine 9815 to a 9835
Old Jul 17, 2006 | 10:10 PM
depechek's Avatar
Default Upgrading from an Alpine 9815 to a 9835
Hi S2kers,
I will be replacing my 9815 with a 9835. The current setup has (don't know the specifics since it came with the car) 9815 with DCI, rear speakers, and bazooka tube. I was just wondering if I could just unplug the (alpine factory) harness from the back of one HU and plug it into the other HU. Will everything work (especially the DCI) as is or do I need to plug/splice any wires? Do I need to reprogram the DCI? Thanks in advance for any help.
Old Jul 17, 2006 | 11:29 PM
smurf2k's Avatar
go to alpine and check out the user manual PDFs.. you can see whether the harness maps are the same.. i would GUESS that they are
Old Jul 18, 2006 | 08:32 AM
goldenfri's Avatar
I did the same thing in my prelude, just took out the 9815 and put in the 9835. The harness matched up perfectly, it looks like they use the exact same harness. Just make sure that you have the power hooked directly to the battery like it tells you, not the fuse box. I fried my 9815 by not realising that when I had it installed at best buy they just hooked it up to the fuse box. That was the last time I didn't just do the install myself.
Oh also they have the exact same remotes so I would assume the DCI should still work fine.
Old Jul 18, 2006 | 11:00 AM
depechek's Avatar
thanx goldenfri n smurf2k. Yup it works, just finish the install. Only thing was the HU chassis needed to be pushed into place, it was really a tight squeeze! I tried moving the wires and connection boxes this way n that but in the end I had my sis push the HU in while I screwed it in place. Anyone else have this problem? I mean how do u guys fit the subwoofer plugs, ipod adapter wires, etc... into that small space? Is it ok that I did that? I really don't feel comfortable that I had to do that.
Goldenfri:
How can I tell if the power is hooked up directly to the battery or not? The harness was spliced and installed by the previous owner's shop. The 9815 is going into the accord so I need to figure out this direct power connecting to the battery thing.
thanx for the help!
Old Jul 18, 2006 | 12:13 PM
smurf2k's Avatar
look at the battery to see if theres an additional cable coming from it
or check the back of the head unit to see whether the yellow cable from the HU goes into the factory harness or it runs out to the battery
though i suppose its not necessary unless you listen to your system loud--using all 27w and drawing higher current in the system
Old Jul 18, 2006 | 12:34 PM
depechek's Avatar
Smurf2k
I didn't see ur post b4 I submitted a new thread, but can I safely splice these two wires together (i usually do it on other installs) or is this a "no no?"
the two yellow wires:
Old Jul 18, 2006 | 01:16 PM
r_duff's Avatar
PLUG AND PLAY. i just upgraded 9815 to 9857. had DCI also. no splicng, no rewiring.
Old Jul 18, 2006 | 01:21 PM
r_duff's Avatar
and no reprogramming
Old Jul 18, 2006 | 02:17 PM
smurf2k's Avatar
Originally Posted by depechek,Jul 18 2006, 03:34 PM
Smurf2k
splice IF you 1) use external amplifier (bypass internal amp) or 2) use internal amp but listen to low level
IF you listen to it loud, youll draw too much current for the stock wires
Old Jul 18, 2006 | 03:19 PM
depechek's Avatar
ok cool, I just spliced it. Thanks for everyones help!
S2Kbastard
Aug 30, 2012 09:18 PM
S2k007
Nov 22, 2010 08:03 PM
The Shocker
Oct 30, 2010 06:28 AM
cshamash
Jul 17, 2006 11:00 AM
jwa4378
Jun 12, 2005 03:57 PM
