Amp question? Difference between
Old Apr 20, 2006 | 12:07 PM
Fusiondynamics's Avatar
Default Amp question? Difference between
I've noticed that the mono amps cost a lot more than 2 channel amps. What is the difference? I noticed a 2 channel bridged gives more power than some mono amps and cheaper.
Old Apr 20, 2006 | 12:23 PM
jwa4378's Avatar
classic AB class 2-channel amps are generally less efficient than a similar class D mono amp. Mono amps are also generally a bit smaller (not much). Most mono amps are also capable of a 2-ohm load (efficiency again....), while most of the AB amps are just 4-ohm stable. You can use an AB amp, just chose your sub accordingly.
John
Old Apr 20, 2006 | 12:54 PM
d-j's Avatar
d-j
What's your application, high-end or average/low end? Mono is better for subs. IMHO.
Old Apr 21, 2006 | 08:29 PM
PJK3's Avatar
FAQ
s2k_redhead
Jul 28, 2006 01:22 PM
INFMS
May 12, 2006 06:59 PM
azndrunkyoon
Oct 23, 2004 05:29 PM
jbotstein1
Dec 12, 2003 10:27 AM
145
Mar 24, 2003 05:58 PM
