AMP recommendations to power 6.5" comp & 10" sub
Old Jul 31, 2006 | 07:46 AM
skim's Avatar
Default AMP recommendations to power 6.5" comp & 10" sub
I'm looking for an amp to power a set of 6.5" alphasonik components and the 10" psw8104.
NFRs200nyc - Dave has been very helpful in guiding me on the right size amp for this application ~ 125x4 @ 4ohms....
So I've narrowed my choices down to the following:
Alphasonik PMZ12005A - $229
http://alphasonik.com/pmz.html
75W x 4 + 200W x 1 Car Amplifier or 150x2 +320x1 @ 4ohms
Alphasonik PMA4150A - $339
http://alphasonik.com/pmaclassab.html
150W x 4 @ 4 ohms
Infinity REF7541A - $250
http://tinyurl.com/nj3yv
111wx4 @ 4 ohms
JBL GTO 75.4 - $250
http://tinyurl.com/qn47h
104w x 4 @ 4 ohms
JBL PX300.4 - $320
http://tinyurl.com/o57va
123.5w x4 @ 4ohms
so the question is, will any of the above amps work? or will any one amp sound noticeably better than the other? also some of the amps have electronic crossovers and some do not, does that affect sound quality or performance?
basically, i'm looking for the best bang for your buck w/out degrading sound quality.
advice and feedback on any of the above amps would be appreciated.
thanks in advance,
steve
Old Jul 31, 2006 | 08:48 AM
Will's Avatar
they all sound like pretty solid choices; also i've been told the Infinity is a bit underrated--you'll likely get more clean power than just the 111w it's rated for. I also like the fact that if you bridge channels 3 and 4, you get 278w (conservatively) for the sub. Then again the JBL GTO 75.4 specs look pretty good also, and IMO I think it's a better looking amp.
edit: my alpine amp has 300wrms going to my 10" audiobahn sub, and sometimes I wish it was more. You may also, depending on your box/sub. If I were shopping for an amp right now to replace my current amp, and I were considering just the amps you listed here, i'd probably get the JBL PX300.4.
Old Jul 31, 2006 | 09:23 AM
NFRs2000NYC's Avatar
The only problems with the Alphasoniks, is they are a bit on the large side. You will have to mount it a little crooked to have it fit on the amp rack from Jim. However, if you use the spare tire cover from Pas2knut, you can mount almost any amp on it. They are all the same level of quality amps, and you will be fine with any of them. In your application, the PX300 would work very well.
Old Jul 31, 2006 | 10:13 PM
smurf2k's Avatar
check dimensions. just cut an (mdf) board on top of toolwell to mount amp on... given enough spare space on both sides so i wont have to kink the RCAs and cables, the JBL fits almost exactly
so, anything a little longer and you might have to worry about room for connections
Old Aug 1, 2006 | 07:26 AM
skim's Avatar
Thanks for all the advice. I decided to go w/ the JBL PX300.4. Now I'm just waiting for John (darkknight) to get back to me about the alphasonik comps and sub....
Old Aug 11, 2006 | 06:46 AM
skim's Avatar
Dave or anyone else on here...
So the JBL amp does 125x4 RMS @ 4 ohms and I plan on bridging the rear channels for the sub.
I'm looking to pickup an 10" sub, so just to confirm before I order it, I could configure either a 10" sub with a single voice coil @ 4 ohms or a 10" sub w/ dual voice coil @ 2 ohms (wired serial for a 4 ohm load as shown here: http://www.rockfordfosgate.com/rftech/wiri...hmDVC_4ohm.gif).
Is there any benefit in one configuration over the other? I'm looking to get the alphasonik 10" 8104J (http://www.alphasonik.com/800.html#psw810j) sub but want to make sure I order the right configuration.
http://www.rockfordfosgate.com/rftech/wiri...ohmDVC_4ohm.gif
Thanks,
Steve
Old Aug 11, 2006 | 10:55 AM
smurf2k's Avatar
dvc will give you more options down the road
V6 Donut
Feb 27, 2017 08:09 AM
oth
Sep 28, 2007 05:31 AM
JP_BLACK
Feb 11, 2005 05:19 PM
azndrunkyoon
Oct 23, 2004 05:29 PM
OC S2K
Apr 30, 2004 10:27 AM
