Amp wire through the firewall?
Old Jul 6, 2007 | 11:51 AM
JackS's Avatar
Default Amp wire through the firewall?
I put this off but have to do this next week.
If a hole must be drilled , where is an ideal place? TIA. Jack
Old Jul 6, 2007 | 02:18 PM
muggzy's Avatar
i put a 4ga power wire through the driver side wire harness, under the clutch res.
Old Jul 6, 2007 | 03:29 PM
listener's Avatar
There's a wire harness under the battery that goes through the firewall. It's tight to reach under there, but I was able to do so without removing the battery. I used a long, thin, screwdriver to puncture the boot, then simply pushed the wire through from the engine compartment side. USE CAUTION so you DO NOT damage the wire harness!!
Old Jul 6, 2007 | 03:52 PM
granturismo's Avatar
I was just going to ask
Old Jul 6, 2007 | 08:52 PM
JackS's Avatar
Thanks guys. Two options is always better than one. Glad to hear that no drilling is necessary.
Old Jul 6, 2007 | 09:30 PM
Suzukuh's Avatar
Yea I did the passenger side as well. I didn't puncture the boot though I just took off the tape and the wire went through no problem.
Bacchus
Mar 19, 2016 04:35 PM
liquidgsr
Dec 6, 2011 05:16 AM
rainyred
May 8, 2009 10:27 PM
s2kmaniac81
Dec 21, 2005 12:50 PM
Fusiondynamics
Feb 3, 2005 09:51 PM
