Another quick alarm Q: Smart Trunk Release for Clifford
Hi again. Thx to those who responded to my last question about about the Clifford Concept 600. I have one more quick question. I have the trunk pop hooked up to button 2 but noticed that pressing the button will pop the trunk even if the alarm is armed thus setting off the alarm. According to the Concept 600 manual:
"The Smart Trunk Release feature requires installer programming, so if you have the optional trunk release installed, you may want to verify that it will NOT
activate when the system is armed. If it can be activated while armed, causing the alarm to sound, please return to your installing Clifford Dealer and have
them correct this (it only takes a couple minutes and there will be no charge to you)."
I was just wondering if there was any way I could do this myself with the valet switch because it is kind of out of the way to go to the installer that I went to.
Thx!
Thx!
I had this exact problem, but the shop noticed it before I left and fixed it there. From what I remember, it involved the same procedure as the night vision option. In other words, the shop can easily do it, but you can too. Check the manual. You will need the key, but the shop should have provided that. good luck.
