Any stereo upgrade recommended?
I just want something that plays digital media, not even need a CD player just play Bluetooth and xm, and something that fits nicely with the radio cover?? I’m afraid of purchasing one that will leave me with an open cover, not sure how much wiggle room is in there...and advice??
Buy one of these, aftermarket radios look bad imo.
edit: Sorry, didn't see that you wanted XM.
https://www.target.com/p/anker-roav-...k/-/A-53938478
there's this that plays media through your phone....not bluetooth but directly wired to your phone.
https://www.blitzsafe.com/catalog/ho...-dmx-v-2x.html
I went something like this: https://www.bestbuy.com/site/kenwood...614&mpid=27795
Has everything you need, Bluetooth, SiriusXM, HD Radio and you can close the center console door (which should apply to any single-DIN head unit, the only thing off my mind that wouldn't work is if it had a motorized LCD that comes out). Can also change the color to red to somewhat match the gauge cluster. No CD player so the chassis is about half length which you should also install a Modifry DCI behind it to get full use of your factory radio controls and then some.
You'd be surprised how many manufacturers don't make a "mechless" head unit with a HD Radio tuner. Some will call it a Digital Media Player but the whole idea is it doesn't have any mechanical parts like a CD player which most people don't use anymore.
I installed a Pioneer Digital Media Receiver that left enough room behind in dash to install a 90W/channel Pioneer class D amp (class D doesn't get hot).
Installed aftermarket speakers. Great, ifnot quite audiophile level sound, and loud enough to easily hear clearly top down highway.
Radio cover closes easily. Set it up with same color pattern as the dash, so blends in well.
Got a Modifry phone mount bracket. Used a phone mount that auto grips phone as you place it, and wireless charges at same time. Stream audio from phone. So between laft side radio dash controls and phone apps really don't need to open radio door much.
You can't get the BT322U anymore, but it fits perfectly behind the radio door. Also, you can set it to matches the colors of your dash. It's been flawless to me.
I'd imagine the new version would too. Also, it's only $90.
https://www.crutchfield.com/p_113BT3...mnews=15166676
It's an extra module that you link up your aftermarket stereo so you can retain your stereo button controls by the starter button. Those buttons are only mapped to your factory stereo. Yank out the factory stereo, and they're useless.
Annnnnnd, I'll be the first to admit I'm spoiled by modern(ish) cars with their big giant buttons (pre-tablet screens garbage). You are not going to enjoy the tiny buttons on a single din interface.
https://modifry.com/index.php?route=...ufacturer_id=1
I got one, the only button that I cannot retain function is the MUTE button. But everything works flawlessly and I barely have to touch the actual stereo. (just like OEM)
