AP1 Heated back glass
So, I got a new top with heated window which I am planning to install, also got OEM harness for it. Car is 2000 AP1, so no button/relay/etc. I am failing to find any good info on how to get it working (maybe I am just blind). Any pointers appreciated. (I can likely get AP2 console/heated window button quite easily).
Reason: Useful in high humidity driving to avoid fogging.
CaR
is 2000 AP1. Lots of solutions be sure to select one that turns the heat OFF after a period of time and has a little indicator light. Default is 15 minutes on my car.
Lots of clues here although it's mainly about the hard top.
https://www.s2ki.com/forums/uk-irela...r-my00-916782/
-- Chuck
is 2000 AP1. Lots of solutions be sure to select one that turns the heat OFF after a period of time and has a little indicator light. Default is 15 minutes on my car.Lots of clues here although it's mainly about the hard top.
-- Chuck
For continuity sake:
Managed to get OEM AP1 center console with heater button (covers the need to modify original panel, button already in) + have soft top connection harness (32119-S2A-000). Now to figure what I am missing and how to tie the two together. Staring at https://www.s2ki.com/forums/s2000-mo...rofit-1211426/
Looks like sub-cord and relay.
I've been trying to find the harness to go from the center console button to the hardtop forever. 32205-s2a-h000 I've talked to friends at Sumitomo who made the harness for Honda as well as custom harness builders and no luck. though the custom harness builders have said if I do fine one they will copy it so people can get them.
