AP1: Turn signal DRL using Switchback bulb?
Anyone know how much work would be involved in a setup with similar results as the NC below? With clear headlight diffusers I feel like this might work. White light at DRL intensity when the engine's started, switching to amber for the signal, obviously. I just don't know where to get the parts required to run the DRL.
Sponsor
There isn't a plug and play option for this. Custom wiring would be required for this, but it is possible. This is because AP1s and AP2s use a single filament bulb for the turn signals.
You'd need to buy a dual filament bulb socket to fit into the turn signals, with 3 wires coming off of them (ground, turn, and DRL)
Ground and Turn you'd tap into the original wiring, but the DRL, you'd wire to a switch or tap into the cigarette lighter fuse.
I stock some switchback LEDs. PM me if you want to know more.
Supernova LEDs - Quality LEDs for your car or truck
BTW, Supernova LEDs is the sister site to JS2k.com.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
