Audio question - need help
Old Dec 27, 2002 | 08:35 AM
#22Benny's Avatar
Default Audio question - need help
I bought an aftermarket head unit without a subwoofer output, and I am using the regular line out speaker outputs for all four channels. If I wanted to use the rear RCA amp outputs to hook up a subwoofer amp with a crossover, would this mute the rear speakers already installed? Are there any other easy ways to do this without buying new equipment?
Old Dec 27, 2002 | 08:56 AM
jeffbrig's Avatar
The rear speakers will continue to work just fine. You can do whatever you want with the RCA output with no effect on the other speaker outputs.
Old Jan 6, 2003 | 10:13 AM
loicweb's Avatar
choose an amplifier with sub crossover and bridge compatibilityy most of them do it
loic from france
Old Jan 6, 2003 | 11:27 AM
mgiang7's Avatar
yeah should work fine, but make sure you set the filter on your amp. on heads with separate subwoofer out--the head will restrict the frequency coming over that wire. if you use the rears you'll get a full signal, so make sure you set the crossover point correctly or set the filter on the amp (which would act as your xover as well).
Ap1s2kay
Jan 14, 2014 04:42 PM
chamorru
May 28, 2009 11:28 AM
zzz36
Jul 25, 2003 08:00 PM
njtripface
Nov 25, 2002 07:23 AM
johnyboy32
Jul 10, 2001 08:26 AM
