Audio ?'s
Old Dec 2, 2004 | 07:00 PM
Will's Avatar
Thumbs up Audio ?'s
I have a "high quality" (not boomy) system in my other car. Now that I have an S2k, i'd like something much stronger than the stock stereo. I'm happy to find DJQube's DCI, giving me alot of freedom in head units... but to start with, I think i'll probably just need to stick to something for the low end. I want something immediately useable, but also compatible with an aftermarket stereo... so I was thinking of getting a powered sub small enough to fit under/behind the passenger seat, with speaker level and rca inputs. Anyone done this? is it enough to satisfy you for a while, or is it not worth it without a new head unit?
Old Dec 2, 2004 | 07:22 PM
Spoonie's Avatar
Well for a little bit of bass and I mean a little bit I would recomend an rsx sub. It fits in the spare wheel and is relatively cheap. You should be able to pick one up for no more then $75 bucks. As for better speakers I went with Focals and they sound amazing. Now for price on those your looking more around $200-350.
ADiSKOTEC's Avatar
There's an electronics forum for this kind of topic.
Old Dec 3, 2004 | 02:17 PM
Tedow's Avatar
Moving there now...
Old Dec 4, 2004 | 06:02 AM
Poindexter's Avatar
For immediate use in the front you'd be best just to start with a powerful Head Unit. After that, you're going to need to start thinking space sacrifices in the front (if you're going to squeeze an amp up there) or start putting things in the trunk.
You can get very creative with the trunk and the trunk mounts are typically going to leave you the most space to keep your amp cool versus the front seat (unless you don't need a passenger seat or a convertible top).
Old Dec 4, 2004 | 04:58 PM
flitcroft's Avatar
Do a search for a WLaurent subwoofer enclosure. They fit in the golf club cutouts on either side of trunk. Sound passes into the cabin easily with no mods and they can remove in 30 seconds. I have two and love them.
For headunits, check out the Alpines at discountjungle.net. That's probably your best best for quality and lower cost.
HTH
Old Dec 5, 2004 | 10:28 PM
vampire's Avatar
first, get a new HU
this will make a huge difference
the stock HU sucks
Old Dec 6, 2004 | 10:58 AM
s2ksimon's Avatar
alpine 9815, larger door speakers 6x9 with an JL Audio sub in rear more than suffices for me.. i'll be installing speakers in rear panel this summer hopefully
Old Dec 6, 2004 | 11:34 AM
flitcroft's Avatar
6x9 in the door? What kind of enclosure do you have for those, aimed kickpanel pods?
I'd recommend using the the stock mounting locations, btw. Helps keep resale value higher (stock sells for more) and 6.5" speakers hold up fine or outperform 6x9's depending on the price point.
Old Dec 13, 2004 | 02:06 PM
60N5.5's Avatar
[QUOTE=Will,Dec 2 2004, 10:00 PM] I have a "high quality" (not boomy) system in my other car.
kapitanemo
Feb 20, 2013 12:38 PM
JAOZZY
Jun 7, 2012 05:24 AM
chung
May 20, 2011 12:10 PM
Wrongun
Sep 3, 2008 09:13 AM
scollops
Sep 25, 2003 12:37 AM
