Aura Bass Shakers ?
Old Feb 5, 2004 | 11:45 AM
E White's Avatar
Default Aura Bass Shakers ?
Would I be able to run rear speakers and the bass shakers off the MY01 OEM headunit without an amp?
Old Feb 5, 2004 | 01:59 PM
MacGyver's Avatar
Not easily. You need to keep a nominal 4 ohm impedance on each channel. You would need to run two sets of each in a series/parallel combination.
Old Feb 7, 2004 | 08:18 PM
Calvin's Avatar
what does that mean in layman's term?
Old Feb 8, 2004 | 09:20 AM
NFRs2000NYC's Avatar
You cant do that because the Auras need 25wrms and the HU only gives about 10 per channel.
Old Feb 9, 2004 | 02:54 PM
MacGyver's Avatar
One is irrelevant to the other...
Old Feb 9, 2004 | 03:43 PM
[QUOTE]Originally posted by MacGyver
Old Feb 9, 2004 | 08:00 PM
MacGyver's Avatar
25W is the max, but they work just fine with less. That's like saying a 100W speaker won't work unless you hook it to a 100W amplifier and always turn it up to the max volume.
"But it goes to 11..."
Old Feb 9, 2004 | 09:07 PM
dierk's Avatar
25 watts RMS is the maximum for the standard model. The Pro model is rated to handle 50 watts RMS.
Old Feb 9, 2004 | 10:21 PM
Oh....well I was misinformed. I thought the were an on/off kinda thing.
You learn something new everyday. Thanks!
Old Feb 11, 2004 | 09:00 AM
Calvin's Avatar
"Not easily. You need to keep a nominal 4 ohm impedance on each channel. You would need to run two sets of each in a series/parallel combination."
Can you describe how this can be done? Would you tap into the rear speaker wires both + and - separately or connect the it on one wire either + or -?
