auto window lowering function disabled ? why ?
Old Mar 27, 2002 | 03:25 AM
ThomasG's Avatar
Default auto window lowering function disabled ? why ?
... hi,
i've put some new speakers into the doors. but now the function of the window up/down button just works when i hold them. the function that they lower and rise completely by pressing the button full down or pulling full up is out of work.
does somebody now an answer ?
Old Mar 27, 2002 | 03:35 AM
lucid's Avatar
maybe its not plugged in all the way
Old Mar 27, 2002 | 07:25 AM
stocks2k's Avatar
Check to see if the drivers window lowers itself when you lower the top. If not the entire assembly probably needs to be replaced. This has been a fairly common problem with the S2000.
Old Mar 27, 2002 | 08:39 AM
ThomasG's Avatar
now its just working ... don't know why it didn't work shortly before i did the post.
hum ... thanks anyway ...
btw. it worked fine with the lowering of the top ...
Old Mar 27, 2002 | 09:18 AM
bbsilver's Avatar
Mine doesn't hold on the down position every once in a while. Just let go and do it again.
I don't have an auto-up feature. Difference between the US and Euro versions?
Old Mar 27, 2002 | 01:45 PM
Alister's Avatar
I had EXACTLY the same problem when I replaced my OEM speakers. The next time I tried it (ie after turning off the ignition and coming back to the car later), it worked no problem and has been flawless ever since. Very strange.
Old Mar 28, 2002 | 12:55 AM
ThomasG's Avatar
maybe the car had to reset itself ? ...
yes, we have auto up at drivers side too ... but i can't imagine why honda should use different switches for the window ...
it may be to the fact that they don't want to get a lawsuit because someone autoupping the window while someone else has his head between the window ...
Old Mar 28, 2002 | 08:14 AM
bbsilver's Avatar
Americans are sue happy. We weren't given the auto-down feature on the Del Sol either. I saw them in Germany when they first game out.
I might order one just to check it out.
Sadayoshi
Jul 25, 2008 06:20 PM
theSILVERone
Oct 3, 2007 09:11 PM
brykel
Mar 23, 2006 09:01 PM
mas
Jan 14, 2003 04:06 PM
Prolene
Sep 18, 2002 06:56 PM
