AUX Input on OEM 2005 S2000 decks?
Old Feb 18, 2006 | 11:19 PM
s4play's Avatar
Default AUX Input on OEM 2005 S2000 decks?
Just curious since I would like to hook up my Ipod to the OEM stereo for now since I'm doing most of the performance / exterior mods before the ICE.
Actually the stock stereo in the 2005 isn't too bad - can't compare to aftermarket but it's liveable for now.
Might drop by Honda dealer tomorrow but wanted to see if anyone here knows a trick to get the AUX input to work?
thanks,
rick
Old Feb 19, 2006 | 05:47 AM
darkknight1999's Avatar
It act like the CD changer I believe. If you don't have anything plugged into it you can't access it. Once you have a unit connected to you you'll be able to select the cd changer.
Old Feb 19, 2006 | 04:57 PM
s4play's Avatar
hmmm, that makes sense...so there is no way to find a 2.5mm jack on the back of the unit that I can tap into for my Ipod?
damn....guess I'm stuck with the lousy FM modulator!
Rick
Old Feb 19, 2006 | 08:10 PM
I believe you can get one that will plug into the stock CD changer port. It will sound way better than a FM modulator, those things suck.
Old Feb 20, 2006 | 06:06 AM
jwa4378's Avatar
. I think Blitzsafe makes one. You will need a 3.5mm-->RCA conversion, then an RCA---> PIE interface to adapt the RCA's to the Honda Aux input.
I think you can get the kit for like $100 from blitzsafe.
John
Old Feb 21, 2006 | 02:37 PM
Dr.Evil's Avatar
I got a P.I.E. unit that plugs right into the CD changer input, cost 50 bucks, works perfectly with my Sirius and my iPod, but I can't remember the name of the website.
The only bad thing is that it is a VERY tight fit when you push your stereo back into the dash. I have since bought a thicker, better quality RCA/mini wire but I am not looking forward to trying to fit everything behind the stereo again.
Old Feb 22, 2006 | 07:06 AM
00CivicSi's Avatar
[QUOTE=jwa4378,Feb 20 2006, 10:06 AM] .
ccajun4real
Apr 4, 2009 02:57 PM
teeteeracer
Jan 30, 2007 08:17 PM
hamsterguy67
Dec 11, 2006 11:21 PM
Kiteland
Jan 16, 2005 09:38 AM
ShifterKart
May 6, 2004 01:03 PM
