Axxess ASWC, Mute button doesn't work
Old Jul 20, 2011 | 07:11 PM
lithoman's Avatar
Originally Posted by gforgary
I've been living without the mute fine, but this is what their tech support sent me:
Step 4 is the mute wire. If it is wired up per the instructions, try tapping the MUTE 2 times.
4) Connect the Orange/Green wire of the ASWC to pin 14 of the vehicle
I've been too lazy to pull out the head unit, but I'm 99% sure I wired it up correctly.
Yes, I know i wired it correctly.
Old Jul 21, 2011 | 10:35 AM
khaosman's Avatar
The tapping two times doesn't work? I haven't tried it yet, but I'll give it a try today.
Old Jul 21, 2011 | 04:18 PM
lithoman's Avatar
nope two taps and nothing happens.
Old Jul 21, 2011 | 06:56 PM
oth's Avatar
oth
The s2000 mute apparently doesn't work the way most of them do - I'm guessing
the tech support guy gave generic instructions for the generic interface and didn't
know the details for a relatively obscure car. If you want the mute and your
headunit supports a hardwired telephone mute, you can probably wire up a relay to
do it.
Old Jul 23, 2011 | 01:55 PM
khaosman's Avatar
I tried mine out yesterday and the double-tap does not work. OTH, you are probably right about it being a generic instruction. I suppose I can live without the mute button, but it would be nice to have that functionality.
Old Jul 23, 2011 | 07:02 PM
oth's Avatar
oth
If your headunit has a hardwired tel-mute wire, you can use a standard relay to connect
the dash mute button to the tel-mute wire of the headunit.
Basically, you use the output from the mute button (yellow/blue wire in the car's harness)
to energize the relay, with the tel-mute wire being connected to ground through the relay
when the when relay is energized.
Old Aug 15, 2011 | 04:02 PM
DeadLock23's Avatar
Any updates on this? I just picked one up will give it a try.........the problem is the mute and the volume up and down are the only DCI buttons I really use......so it would be nice for the mute to work....
Old Aug 15, 2011 | 04:11 PM
lithoman's Avatar
Sorry no mute yet....but to be honest i haven't tried to fix it.
Old Oct 22, 2011 | 02:12 PM
00derek
Guest
Posts: n/a
instead of connecting the switched 12v from the vehicle harness (pin 2) to the HU (red wire), connect the mute wire (pin 14) to the HU switched 12v input.
now you have power on/off from the mute button.
FREEK
Dec 27, 2007 06:28 PM
TrackStar
Jul 10, 2007 07:29 AM
Allstar
Jan 20, 2007 08:02 PM
mr_grand_prix
Aug 23, 2005 05:55 PM
badkins
May 25, 2004 08:38 PM
