Mute Button
Old Jul 9, 2007 | 08:06 AM
TrackStar's Avatar
Default Mute Button
Just installed a pioneer p690ub and I connected the mute wire to the car and now sometimes the deck will switch to mute by itself and I have to turn the mute button on on the dash controls. I'm not using a DCI or anything else. Do I have to just disconnect that wire? Thanks
Old Jul 9, 2007 | 08:45 AM
Dave-ROR's Avatar
What wire in the harness did you connect the mute wire from the HU to?
Old Jul 9, 2007 | 08:53 AM
TrackStar's Avatar
yellow blue
Old Jul 9, 2007 | 08:55 AM
TrackStar's Avatar
Does the mute function have it's own fuse I could pull?
Old Jul 9, 2007 | 02:19 PM
modifry's Avatar
Honorary Member
The two mute systems (dash mute switch and the HU mute input) are EXACT opposites. The dash switch puts out +12v when muted and the head unit expects a ground when muted.
This does not mean the HU will work the opposite of what the switch says, because the dash switch never puts out a ground - it's either +12v or nothing. When it's "nothing" the HU doesn't know what to do so it randomly goes into mute. Turning mute ON at the dash provides +12v which the HU sees as "not muted". But, it could just as easily fry if it's a typical HU and has a pullup to +5v, or the dash switch circuit could fry too. You're never supposed to connect these circuits together. Disconnect it!
You need to install a relay to convert the +12v from the dash switch to a ground that the HU can use. Make sure it's a low current relay, not a typical "ice cube" automotive relay. If you don't know what I'm talking about get some help before you fry something.
Old Jul 10, 2007 | 06:26 AM
TrackStar's Avatar
Thanks man! I got cut the cord as soon as I get home!
Old Jul 10, 2007 | 07:29 AM
TrackStar's Avatar
Modifry is the man! I just snuck out of the office and fixed it. Thanks for saving me the $250 for a new head unit.
hutsori
Dec 19, 2011 01:32 PM
gforgary
Oct 22, 2011 02:12 PM
FREEK
Dec 27, 2007 06:28 PM
Allstar
Jan 20, 2007 08:02 PM
mr_grand_prix
Aug 23, 2005 05:55 PM
