BLANK CLUSTER Ap1 into ae86
Old Jan 12, 2018 | 03:30 AM
Jin_Muff's Avatar
Default BLANK CLUSTER Ap1 into ae86
Greetings Guys
Wondering if anyone is able to help me.
I recently installed an Ap1 swap into my 86. The car was wired and the display was working on start up and idle for the initial stages.
However after my first test run in the car, within 500 Meters the display blanked out. I can no longer see any feedback ( no temperature, no gas, No rpm & No Kmh)
The only signal I'm receiving is the green key. When we checked the ignition wires on my car is getting extremely hot.
I have since plugged out the display checked the wires for a shortage and even opened it to see if there is a fuse to be blown on the inside. I can see no physical damage.
Can anyone give me an idea of how to solve this problem? Has anyone experienced the shutdown of their cluster?
Could i have an ignition problem that is affecting the Cluster?
Would truly appreciate some insight.
Old Jan 12, 2018 | 06:11 AM
noodels's Avatar
People use a black box on other Hondas,could be step down/up resistors.
http://www.marklamond.co.uk/products/s2000/s2000.htm
Old Jan 12, 2018 | 06:32 AM
Jin_Muff's Avatar
I'll do some more reading and see if I missed something.
However in my case it is a full swap.
All sensors ecu cluster tranny, eerything is from a 2002 ap1.
Old Jan 12, 2018 | 07:29 AM
Madr0x's Avatar
I would think to look at your source to the cluster since that should be the only thing coming from your corolla chassis.
Old Jan 12, 2018 | 09:32 AM
flanders's Avatar
Ignition wires gets extremely hot? If so you need to find the cause, it could be linked to your cluster problem.
I would use an amp meter and start unplugging things until you see the current drop significantly.
Are you using a stock AP1 ecu?
Old Jan 13, 2018 | 03:17 AM
Jin_Muff's Avatar
Yes i am using a stock ecu. However i am trying to switch to the aem 30-6052.
I tried unplugging a few things, didn't see a change. must be a deeper underlying problem. I'l have to keep searching.
Old Jan 13, 2018 | 03:18 AM
Jin_Muff's Avatar
Well it is.
what we did was to splice into the wires from the original harness to get the features from the ap1 cluster.
such as indicators etc.
Old Jan 14, 2018 | 05:02 PM
Madr0x's Avatar
Originally Posted by Jin_Muff
Well it is.
Right. So ignition turn is closing the circuit supplying your 12v to the ecu/cluster. Have you tried bypassing the ignition switch and taking 12v directly to the cluster? That will rule out the cluster and point you else where. I would certainly double check your ignition as well like mentioned.
Old Jan 15, 2018 | 02:45 AM
Jin_Muff's Avatar
This hasn't been tried yet. We will try that the next chance we get to work on the car and see if this reveals anything.
Great idea though. Thanks
JeffreyMartin
Jun 25, 2012 07:27 AM
fastflyer52
May 27, 2012 08:14 AM
JAY_S2K
Apr 6, 2011 01:59 PM
kjcs9
Jan 4, 2011 09:21 AM
Live_Wire
Dec 25, 2007 05:01 PM
