blew up ignition?
Doing a LS1 swap. I was trying to wire up my starter. I had the signal wire that engages the starter solenoid wired up. Withe solenoid would pop when I kit the start button.
When I tried to wire up the power to the starter, I'm guessing the wire I had ran from the battery to the starter was the ground stud on the starter.
Now when I turn the key in the s2000 nothing happens. No dash lights, nothing.
40amp fuse is good
100amp fuse is good
I believe all other dudes are good
Is there a relay I fried? Where? Which one ?
Did I get the ignition ?
40amp fuse is good
100amp fuse is good
