bose sub wiring
Old Feb 24, 2007 | 01:42 PM
gt489's Avatar
Default bose sub wiring
i cant find a wiring diagram for the bose sub into my s2000 and help please
Old Feb 25, 2007 | 10:35 AM
gt489's Avatar
anyone
Old Feb 25, 2007 | 02:39 PM
thetz99's Avatar
Save yourself the trouble and get a separate amp to drive the speaker...the bose amp not only is underpowered, it "pops" when the audio signal drops between songs.
Old Feb 25, 2007 | 02:51 PM
PokS2k's Avatar
The Bose sub is not strong and a separate amp and sub would be better, but this is a cheap solution that can add some bass. The pop issue was also solutioned.
Here is the link to the wiring thread.
Bose Sub wiring
Here is the "Pop" problem thread and solution. The fix did eliminate the pop.
Pop fix
Old Feb 25, 2007 | 03:04 PM
00wreckedS's Avatar
ahha bose is nothing special! aftermarket is way better
Old Feb 25, 2007 | 07:54 PM
gt489's Avatar
i just want a little bass nothing that need to travel far just inside the car
Old Feb 26, 2007 | 01:57 PM
thetz99's Avatar
As an enclosure that fits INSIDE the spare tire, the bose is great. I still recommend getting a cheap one channel 100W amp ($60ish) to drive the speaker and bypass the bose amp and wire directly to the speaker.
Old Feb 26, 2007 | 02:28 PM
SheDrivesIt's Avatar
thetz99 did you check the impedance of the driver? 4 ohm, 2 ohm, 1 ohm? It is a Bose driver after all.
Old Feb 26, 2007 | 02:42 PM
thetz99's Avatar
You are going to gain match the additional amp to the system so you don't have to worry about blowing the lil bose speaker coil. If you want a bass fill in the cabin, hard to beat this lil enclosure...
Old Feb 26, 2007 | 05:41 PM
I'd be more worried about frying the amp with a 1 ohm load. Guess I'll toss an ohm meter across the driver on the one I have in the basement.
