capacitors...
Old Apr 17, 2009 | 12:03 PM
  #21
DFWs2k's Avatar
yea, that was clearly described on the amp, its like + from 1, - from 2, + from 3 and - from 4, but it had "bridged" and big arrows on it, so i'm 100% that part is correct, lol
Old Apr 19, 2009 | 10:51 AM
  #22
DFWs2k's Avatar
ok got the amp tuned, the xovers were set to full instead of low, and a bunch of other things were jacked up (frequencies, the voltage, stuff like that), subs are acting the way I was thinking they should now, thanks again for all the help!
Old Apr 19, 2009 | 10:57 AM
  #23
Neutered Sputniks's Avatar
No prob. Glad you were able to get it tuned.
Old Apr 22, 2009 | 05:49 AM
  #24
DFWs2k's Avatar
Hey Sputniks,
Have you purchased any high-current/more powerful alternators before?
Do you know a good place to source them from?
Any input on a type of battery to use? I had a Optima Yellow in an older car, but it seems the quality of the Optima Yellows in the s2000 size was lacking...
Old Apr 22, 2009 | 12:49 PM
  #25
Currently I have an Optima Yellowtop in my S. Haven't had any problems with it - but they appear to be hit or miss.
The truck has a DEKA intimidator series (same as yellowtop, just less expensive).
I've heard good things about Kinetic and Powermaster batteries as well.
According to Jacob, owner of Sundown, any AGM battery should be good.
As far as alternators go, I haven't had any rewound. It's on my list of to-dos, but not high enough for me to have done much research. Let me see what I can find for you
Old Apr 22, 2009 | 01:31 PM
  #26
DFWs2k's Avatar
cool thanks, i'll start researching DEKA to see if they have a s2000 size available
Old Apr 22, 2009 | 01:40 PM
  #27
DFWs2k's Avatar
looks like DEKA doesn't make a 51 size...yellow top is only $150, so i'll probably just go that route...
Old Apr 22, 2009 | 02:14 PM
  #28
Look into the Powermaster series.....
D5100 or D5100R.
Old Apr 22, 2009 | 05:26 PM
  #29
DFWs2k's Avatar
damn....over $200...almost twice the reserve capacity and weighs 10 lbs more...i don't know that i would necessarily need all that if i get a better alternator, plus it looks like the terminals may be a little harder to access...i had good luck with the yellow top before, i'll probably go that route again
Old Apr 22, 2009 | 05:46 PM
  #30
I think you'll be fine with the yellowtop. If not, you can always upgrade to the Powermaster at a later date
