Ceiling light doesn't work
Old Oct 17, 2004 | 09:59 PM
ideugene's Avatar
Default Ceiling light doesn't work
My interior light doesn't work when you open the door. It works fine when you turn on the lights either by the switch on the buttons. I have the modifry lighting mod if that matters... Also, during the summer some of the soldering melted from the heat and displaced a small piece on the mod... dont know exactly what it is but i soldered it back and it worked fine... but it just completely went out all of a sudden... why?????
thanks
Old Oct 18, 2004 | 09:43 AM
r_duff's Avatar
whoa you're sodder melted in the sun!? is that possible?!?!?!
Old Oct 18, 2004 | 12:34 PM
ideugene's Avatar
i mean it wasn't like boiling... but the solder probably got soft enough for the thing to move...
can anybody help?
Old Oct 19, 2004 | 04:59 AM
ideugene's Avatar
anyone?
Old Oct 19, 2004 | 07:23 AM
MacGyver's Avatar
HIGHLY doubtful the sun was able to melt your solder... standard Radio Shack style solder doesn't soften until about 425 degrees F... your whole car would have been toast The more likely scenario... it was a cold solder joint just waiting to break free, and enough vibration finally caused it to.
Old Oct 19, 2004 | 07:31 AM
ideugene's Avatar
i thought of that... but when i got out of the car it worked fine... left the car in the parking lot for a couple hours... then when i went back it was on because the piece had moved and bridged two wires... so the solder must have softened? no clue....
but thats not my problem anymore! the problem is that the light doesnt work! help me!
Old Oct 19, 2004 | 08:54 AM
MacGyver's Avatar
I can practically guarantee the solder never softened. The heat may have contracted a wire or a piece of plastic, and THAT put everything back into working order, but the solder didn't soften.
Check the actual switch in the overhead... it may have gone bad.
Old Oct 19, 2004 | 09:56 AM
xviper's Avatar
Does it work when you open the other door? If it does, then look to the first door's switch grounding.
ryanfeldman
Aug 29, 2013 07:20 PM
spoonsol
Mar 9, 2013 11:24 PM
vtec4life57
Dec 22, 2010 12:20 PM
sillyboybmxer
Mar 21, 2010 07:20 PM
jfw432
Feb 5, 2009 01:12 AM
