interior light has a glitch
Old Mar 20, 2010 | 09:54 PM
sillyboybmxer's Avatar
Default interior light has a glitch
on the middle setting(so it comes on when you open the door) it has decided that it wont come on unless i apply slight pressure to the switch, sometimes it stays on when i let off, sometimes it shut off. If i switch it all the way to the right so the light stays on when the door is closed,.....it works fine. Is this a connection issue with the bulb???? any help is appreciated.
Old Mar 20, 2010 | 10:42 PM
Ankur194's Avatar
Interested...mine has a mind of it own too. With the right wiggle or just a press it will work
Old Mar 21, 2010 | 06:37 AM
CapoArgentino's Avatar
Banned
Sounds like the switch contact plates may be dirty or a bit worn. A piece of fine sand paper on the contacts should do the trick. Not much to it, its a simple mechanism.
Old Mar 21, 2010 | 08:39 AM
tudernos's Avatar
The samething happened to my dome light. Just open the assembly and make sure everything is tight and secure. Then you're good to go!
Old Mar 21, 2010 | 08:43 AM
SeanSerino's Avatar
Mine does the same thing. I'll take it apart this week sometime and hopefully fix it.
Old Mar 21, 2010 | 12:07 PM
just took it apart, if you are gonna do this be careful because there is 2 tiny springs and 2 bb sized bearings for the switch that you can lose easily. there was a bit of green corosion on the contact plates that i cleaned off. and put it back together and plugged it in. Now NOTHING worked!!!! so i took it apart again, double checked,.......still nothing!!! so i said F it and put it all back together and when i was screwing the whole plate back into the frame the lights came on,....hmmmm
Old Mar 21, 2010 | 05:04 PM
MP2k's Avatar
The how-to is here Clickme
Old Mar 21, 2010 | 07:20 PM
Moddiction's Avatar
Former Sponsor
Yeah popping it open should show a little dirt or goo covering the contacts That's what happened to mine. Wiped it with a rag and put back together and works great.
Maddog308
Oct 24, 2016 12:04 PM
j8mie
May 14, 2016 02:31 AM
s2konroids
Mar 20, 2010 04:46 AM
tk416
Jan 27, 2009 06:45 PM
element202
Jul 21, 2008 12:28 PM
