Center Console lighting Issue AP2
Old Oct 16, 2012 | 06:34 AM
Jeremy Clarkson's Avatar
Default Center Console lighting Issue AP2
I am having an odd issue with the lighting of my center console switches - defroster, hazards, roof. When i purchased my car the roof switch would flicker when the lights were turned on. A light tap on the top of the switch would generally fix the issue. I have had no issues raising or lowering the roof which led me to believe that the light in the switch was just bad. However, recently the defroster switch has stopped working as the switch is not back lit however the light that lets you know the defroster is on has stopped working. Now I am not sure if this is just the light or if the defroster is not working since I have not had a reason to use it yet, but I will probably need wit with winter approaching. I have not had any issues with the hazard switch. All of the fuses are good. Before I started buying new switches from Honda... or Qube engineering. I wanted to see if anyone has had issues similar to mine and how they went about fixing them.
Old Oct 18, 2012 | 09:05 AM
dsthez's Avatar
that sounds like you have a loose connection somewhere I'd take all the center console apart and reattach all the electrical connections and pray. I had my roof light go out and replaced the bulb from Honda that wasent even that easy good luck.
Old Nov 5, 2012 | 07:48 AM
you mean the bulb inside the actual switch? How much was the part? I messed around with the connectior for 30min before I gave up. If you can replace the bulb inside the switch without replacing the switch itself that would be awesome. It would save me a little but of money.
Old Nov 5, 2012 | 11:18 AM
spider2k's Avatar
Active Streak: 30 Days
http://www.hondaautomotiveparts.com/...atcgry5=SWITCH
RobinA3
May 5, 2015 10:21 AM
PreSsieGuY
Aug 6, 2011 01:32 AM
thefishstick
May 2, 2010 02:45 PM
bikemechanic
Jan 30, 2008 12:04 PM
Saki GT
May 8, 2007 03:11 PM
