Class D amp
Old Sep 27, 2007 | 05:04 PM
jwa4378's Avatar
[QUOTE]
Old Sep 27, 2007 | 07:41 PM
Looneybomber's Avatar
Originally Posted by jwa4378,Sep 27 2007, 09:02 AM
I would be careful about making a blanket statement like that.
You're underestimating what I consider a "quality" amp as I also stated in my post. Assuming amp A and amp B both have input inpedances of 10k ohms or higher, and can both put out the same amount of power with .01% THD or lower, you will not be able to tell the difference between them when hooked up to a sub.
Some amps, when hooked up to full range speakers will sound "bright, warm, dry, ect." whatever adjective people like to describe them with. That's comprised of the architecture of the amp and also input impedance interacting with the output from the source unit. By maintaning the constants of output power, distortion and input impedance, that only keeps amp layout/architecture in play which is the only "character" I am talking about in my post.
What you're talking about is comparing crap amps vs. good amps. Sure there will be a huge difference. But comparing high quality amps and deliving the same amount of undistorted power to your sub, you will not audibly tell the difference. Now if you compare two different amps, but have the gains set so that one delivers 100W while the other 110W, there will be a difference between A and B comparisons.
That is why I say 99% comes from the sub/enclosure and the other 1% comes from the amp assuming you use quality amps.
Old Sep 27, 2007 | 07:58 PM
Originally Posted by jwa4378,Sep 27 2007, 05:04 PM
And I believe that the shape of the box has a lot to do with the sound output, not just size. A box should always be designed to the subs required operating volume. As long as the volume is the same, the shape will really dictate the overall sound and flow of the sound waves. WLAURENT, for example, I believe individually tunes his boxes to follow a certain slope... depending on the sub utilized.
Shape of a sub enclosure is fairly negligable, due to the length of the sound wave in those lower frequencies. Shape is, however, an integral part in designing home theater rooms! At 35hz, the sound wave is 32.2ft long. No matter what you do to a sub enclosure, that wave is going to bounce around inside there like crazy...unless you make the enclosure longer than half the wave length. That is one of the reasons why we line or partially fill our enclosures with "poly". So make the box as big as you can live with, then pick out a driver suitable for that size enclosure.
Old Sep 28, 2007 | 05:31 AM
sam_spider's Avatar
Site Moderator
Community Influencer
Based on this quote, I am drawing the conclusion that you believe a JL 10w6 will sound the same as any other sub with the same power handling characteristics.... I could not disagree more. Some subs are designed to be more "musical" than others and handle the milder-bass frequencies better (SEAS Lotus, for example), while others are designed more for SPL (JL w8 series, for example).
I do agree that the box is a major component, but I think it makes about two thirds the sound. The other third, IMO, has to do with sub selection and amp selection. I will concede that when you get into the area where the sub/amp combo are significantly affecting the sound, the wires and all that stuff will also be brought into the equation...
Just my opinion.
John
John - I agree with what you are saying, and yes different subs are designed for different purposes, most definitely. I was commenting on the same sub, same box different amp scenario, although in same class issue.
I was trying to not down play the box, which is very important in SQ for the sub to perform properly. The amplifier debate is a whole other issue, but I don't think we disagree on that issue at all.
Sam
crav3s2k
Jun 10, 2008 07:50 PM
skim
Aug 11, 2006 10:55 AM
JP_BLACK
Feb 11, 2005 05:19 PM
Nside
Jan 15, 2002 05:26 PM
ace039
Jul 23, 2001 08:43 PM
