component speak problem
ok so i just re-installed my component speakers (2 speakers, 2 tweeters)...i connected them to my HU...question: would it matter if i hook up front left, rear left, right rear, right front with any tweeter or speaker since my HU outputs the same 52x4W for each?...would (-) (+) connections make a difference?...i installed and all speakers and tweeters work but when i turn past a certain point (amount to midpoint on volume scale)...i get static crackling noises from both tweeters...is it connection problem like loose wires or wrong connection itself, or is it becuz the HU can only put out a certain amount of power and its the max???
thanks in advance
thanks in advance
Originally Posted by imdarkrider,Sep 18 2007, 10:10 AM
if you hook positive and negative up incorrectly you reversed the polarity and you'll get distortion... check that first.
