Clifford 5.1 goes 10 seconds after arming
Old Aug 6, 2007 | 08:07 AM
tifosi360's Avatar
Smile Clifford 5.1 goes 10 seconds after arming
I had Clifford 5.1 installed in my car at S2KI sponsor shop. The install experience was horrible with them even though they came highly recommended from this site. I am still debating whether to post further about my experience. Anyways, when I arm the alarm after driving; it will go off about 10 seconds of arming it. When I disarm the system and rearm it will not go off in 10 seconds. It will function properly. Is this a settings issue or an install problem? I don't want the installer to touch my car again. Any ideas?
Thanks!!!
Old Aug 6, 2007 | 02:25 PM
SP-1's Avatar
this happens to me occasionally too, but I have the 10.1
Old Aug 6, 2007 | 04:33 PM
jettfiery's Avatar
hmm... is the timing exactly the same every single time? I'd say take it back and ask them even though u didn't have a good experience. You did still pay for it.
Old Aug 6, 2007 | 05:14 PM
itsmylittlebrothersbike's Avatar
I know you don't want to, but you should let them make it right. Keep us posted.
Old Aug 6, 2007 | 05:25 PM
imdarkrider's Avatar
when you disarm your car how many chirps do you hear?? if your hearing 4 it's your shock sensor and it's set to high , if your hearing 3 they probably have something hooked up wrong. tell them they need to pulse the door trigger along with the lock output at the same time and diode isolate it (they'll know what i'm talking about)
Old Aug 12, 2007 | 05:10 PM
IShift@9v1's Avatar
Banned
Look in the install manual under the long term event history. It will show you the last several times the alarm was set off and what triggered it by way of led flashes.
Find out which zone is setting the alarm off and have it fixed.
Does the S's dome lights stay on for ten seconds after you get out of the car, not looking at mine right this second. If so, then the door trigger is backwards, meaning they used a positive when they should have used the negative (example only). The reason why it doesnt do it on rearm would be because the dome lights are already off by then and there is no voltage discrepancy for the alarm to see.
Seimo
Jul 17, 2012 09:30 PM
sfrederiksen
Dec 29, 2011 04:40 PM
xlaox
Jul 6, 2007 10:24 AM
StEVEN_s2k
28
Jan 18, 2007 10:56 PM
Globetro
Feb 8, 2002 08:11 PM
