Component Setup
Old Oct 5, 2010 | 10:05 AM
ljsimp's Avatar
Default Component Setup
Hey guys,
My car audio sound quality is low, and terrible sounding I need your help.
The setup I have is:
2001 Honda S2000
Alpine CDA-9854L Deck
2 Alpine 2010 Component Type R (crossovers in door)
Alpine MRV-F345 Amp
2 sets of RCA's going to the back
The amp is bridged
What is a good place to start to setup the amp, and the deck configuration? Also how should the wiring to the amp look when bridged + RCAs? I want to make sure I have it setup correctly since I am very new to this.
My goal is to just have a nice sound quality coming out of my deck and so far I feel like crap when my buddy has a OE s2000 speaker system louder and clearer then mine.
Thanks!
Old Oct 5, 2010 | 06:32 PM
darkknight1999's Avatar
Given the equipment you have... your stereo should drowned out your friends.
Here's the manual for your deck:
http://vault.alpine-usa.com/products/docum...%20OM%20ENG.PDF
Who installed the gear?
Old Oct 6, 2010 | 05:40 AM
ljsimp's Avatar
I did, after doing some research yesterday I found out that I should not be bridging those speakers since my amp is not designed to do that. Instead I should plug speaker 1 into channel 1, and speaker 2 into channel 2. I still will need to run two sets of RCA's to the rear though.
I also made some labels last night to label all my cables positive and negative, left and right.
I was told to disable the defeat option in my deck, and to adjust the parametric eq to whatever sounded good to the ear. I have adjusted my time correction correctly.
Do I need to mess with anything on the amp I planned to set the hz to 75-80, and on high pass. I am not sure what to set the gain or anything else to.
Thanks
Old Oct 6, 2010 | 05:46 AM
lovegroova's Avatar
Just to be clear, do you have 2 or 4 RCA plugs to go into the amp?
Old Oct 6, 2010 | 07:13 AM
ljsimp's Avatar
I have 4 plugs. red/white red/white
Old Oct 6, 2010 | 07:28 AM
lovegroova's Avatar
How many speaker wires do you have going from the amp? Are wires connected to all 4 outputs?
Old Oct 6, 2010 | 11:31 AM
ljsimp's Avatar
2 wires coming from the xover that is in each door, so 4 wires +-
Old Oct 7, 2010 | 03:05 AM
lovegroova's Avatar
Have a look at this thread https://www.s2ki.com/forums/index.php?showtopic=821156
Old Oct 7, 2010 | 03:57 AM
ljsimp's Avatar
Originally Posted by lovegroova,Oct 7 2010, 03:05 AM
Awesome thank you
TheKleinschmidt
Aug 19, 2012 10:35 AM
blueap2
May 2, 2008 08:15 PM
ebeldesign
Jan 11, 2007 10:18 PM
00S2K01S4
Apr 5, 2006 09:42 PM
s2k_PikeStyle
Apr 5, 2004 09:53 AM
