Convertible Top Control Unit
Old Jun 14, 2021 | 05:02 AM
JB Morrison's Avatar
Default Convertible Top Control Unit
I am having issues on my AP-1 with the left-hand door window not sequencing (retracting) while opening the top; is there a procedure for resetting the Convertible Top Control Unit or just replace it?
TIA,
JBM
Old Jun 14, 2021 | 07:58 AM
oth's Avatar
oth
There are numerous threads out there, some people have success with the reset procedure, others need to replace the regulator.
Here's one.
Here's another with a different procedure from overseas, allegedly from the service manual, but I couldn't find anything similar in
the US service manual.
Old Jun 14, 2021 | 11:11 AM
Here's one.
I have the service manual too, and have not found a “reset” procedure for the Convertible Top Control Module as well. Thanks for the link about the faulty window regulator, but the faulty ground doesn’t make sense, as the window functions normally through its respective switch. I’m going to try disconnecting the battery for a few minutes to see if that does a reset, if not, then likely CTCM is faulty?
JBM
Old Jun 14, 2021 | 05:31 PM
oth's Avatar
oth
Does autodown work with the driver's door switch (as opposed the roof switch)? If not, it's not the CTCM.
This is a very common problem in early cars - the faulty ground is allegedly in the window regulator itself,
I feel like I've heard it's a bad solder joint but I could be making that up.
Old Jun 15, 2021 | 06:30 PM
mm
Yes, the "Autodown" function through the window switch works normally. So, based on your premise, the window regulator is OK, suspect the CTCM?
JBM
Old Jun 16, 2021 | 06:35 AM
oth's Avatar
oth
Couple more questions:
Does the driver's window go down partially or not at all when you operate the top switch?
Passenger's window goes down completely?
I still think the CTCM is unlikely to be the problem, more likely a bad connection somewhere
along the way. With the Electrical Troubleshooting manual you can find the correct connector
under the right side dash and check if there's a signal on the driver's window down wire.
If someone had reason to disconnect/reconnect any of the connectors along the way, they may
not be seated properly or they may have bent a pin.
Old Jun 16, 2021 | 07:40 PM
Driver’s window (left) drops maybe 1 inch with the initial action of the “Roof” switch, then will drop another 1 inch with successive motions of the switch. Passenger (Right) window retracts completely (normal) with the initial activation of the “Roof” switch. Both windows function normally though their respective switches.
Old Jun 17, 2021 | 09:45 AM
oth's Avatar
oth
That behavior is completely consistent with the window regulator problem - as I understand it,
the CTCM sends a pulse to the window regulator, similar to the autodown from the door switch,
and the regulator goes into autodown mode, unless it doesn't.
I'm surprised autodown works from the door switch though.
If you haven't already, seems worth trying the "reset" methods, but if it doesn't fix it I still think
it's the window regulator, not the CTCM.
macr88
Electronics
Nov 30, 2010 04:42 PM
schmittx
Nov 30, 2010 03:21 PM
badboy00z
May 14, 2009 03:07 PM
WindchaserS2K
Mar 30, 2006 10:27 PM
AusS2000
Jan 14, 2002 12:03 AM
