To cut or not to cut...
And there is some minimum pre-wired for the rear speakers, no need to run speaker's wire all the way to OEM Head Unit.
Is that only true for my04? If not where do I find those wires that are already pre-run?
thanx,
devon
thanx,
devon
i think the "Euro Frame" size you're referring to is often known as a 6.5" Metric fit... and as best as i know, that is what the S does fit... i don't know if you'll have a perfect bolt in or not though, as depth and hole alignment will factor into the question...
the Phoenix Gold Tantrum 600.4 seems to be a commonly approved of solution for an amp for that type of combo. there are other options as well, just make sure that if you're going w/ the e8A, make sure the amp is stable mono to 2 ohms.
FYI
My Eclipse 6.5" speakers are reported to be 3" deep. I have a spacer that brings them to the height of the OEM speakers and they just barely fit. The window hit slightly and I had to adjust the depth.
...just aggrivation that I had to cut my baby!
