A/D/S equivalent / suggestions
Old Mar 17, 2003 | 09:12 AM
ricosuave's Avatar
diamond audio is very comparable.
Old Mar 17, 2003 | 06:12 PM
lucid's Avatar
I agree on diamond Hex series. I think the S600S offers the most performance for the dollar of any I've used or seen.
Old Mar 19, 2003 | 03:20 AM
CoralDoc's Avatar
Originally posted by cdelena
I have only looked at one speaker (rear only ~ a year old) and it is clearly damaged with a small separation on one edge, but none of them sound right.
By "edge" do you mean the flexible material holding the cone to the frame? If so, this is consistent with damage that I have observed on speakers that deteriorated due to environmental conditions. Foam surrounds are particularly susceptible to this degradation. I'm not saying that's the only reason that the speaker could have failed.
Originally posted by jeffbrig
It doesn't matter how much clean power the amp can deliver. At some point approaching max volume, the output signal from the head unit will begin to clip.
I completely agree that you can overdrive any speaker even with the best amp on the planet. What I was trying to say was that cleaner, more powerful amps can drive speakers to much louder levels without damage compared to lower performance amps. I'm using a 40W/channel MTX amp in my car and can acheive very high undistorted listening levels, so I was surprised that anyone would drive Chris' setup so loud that it would damage the speakers ... without damaging their ears, that is .
Any followup info Chris?
Old Mar 19, 2003 | 05:32 PM
cdelena's Avatar
Turns out it is just one speaker, and the cut I thought I saw was really a shadow. Upon careful examination the surround is fine.
The reason I thought the others sounded bad was I could never turn up the volume because the one speaker makes a loud popping noise at higher volumes with certain frequencies. Could the cross over for this one speaker cause that?
Originally posted by mas
PS: Have you checked for a short? I can't help but think there's something wrong, all 4 speakers blown at the same time does not make much sense to me. A short in the speaker wires also sounds like blown speakers, I think. Also, I had this sub at one time with the surround all cracked and it still sounded good. So, spend some time and try to figure out if there something else wrong first, you might even save the $450 ;-)
I looked for a short and nothing is obvious. Probably is none since it is fine at lower volumes.
I just have not had the time to experiment, and I
Old Mar 19, 2003 | 05:59 PM
matrix's Avatar
[QUOTE]Originally posted by cdelena
[B]Could the cross over for this one speaker cause that?
Old Mar 19, 2003 | 06:36 PM
mas's Avatar
mas
You can try swapping the speakers (or the crossover) from left right. This should help isolate if it's the corssover or the speaker. Where are the crossovers for the rears installed? You need to spend some more time doing more experiments to figure out what's going wrong. Unless you do so, it's not a good idea getting new speakers. What do you have for HU? Maybe there's something wrong with it instead? Try swapping the RCAs left/right as well.
Good luck man!
PS: What did the dealership fix on your car? I know they once opened up my door to check the window switch and screwed up the connections from the crossover to the tweeter in the door. I could feel the difference in sound right way. I had to open it myself and fix it later.
[B]Turns out it is just one speaker, and the cut I thought I saw was really a shadow. Upon careful examination the surround is fine.
KillerCom
Mar 2, 2012 07:24 AM
VTEC Racer
Dec 27, 2008 08:48 PM
Jooboy
Mar 3, 2007 10:21 AM
myculito
Feb 16, 2007 10:12 AM
ACB
Sep 27, 2001 07:55 AM
