Dash cutting club
Does anyone have pictures of the back side of a LHD dash? I pulled the radio front bezel bracket thing out today to install the 20th anniversary door and took some pics up in there with my phone and it looks like the mounting points for the navigation cage are there, but I'd like to see what the dash itself looks like from the back side before I tear the car apart just in case I need to buy some more screws to mount this thing.
There’s two mounting point (vents) in the way that have to be cut but are replaced by the JDM bracket as circled above.
I'm finally getting around to dipping my toes into the dash cutters club. I purchased a spare dash to do test cuts and mock up the JDM parts to try an predict any obstacles before I started cutting my original dash. I ran into my first obstacle, the vent I circled above (right) has a screw inside that goes into the OEM mounting point (before I cut it off to test the bracket). I have yet to look inside my car but is there an easy way of accessing that screw?
whoops i mean in my thread on this haha
https://www.s2ki.com/forums/s2000-el...nture-1209126/
The tough part of trying to do it all with the dash in the car is cutting the 2 mount legs that are in the way of where the JDM bracket goes I think
@kalm_traveler Did you ever get around to 3D printing the bezel? Also, where did you source the JDM navigation brackets? I did a quick Google search and couldn't source them locally and the JDM retailers don't have them.
The metal mounting brackets that screw into the side of the deck and into the black plastic mounting cage thing is what I'm assuming you're asking about? I had to order them through Amayama https://www.amayama.com/en since they are able to order OEM parts from Honda directly there in Japan.
