DCI installation? Need help
Old Jul 29, 2004 | 11:34 PM
supman's Avatar
Default DCI installation? Need help
Hi, I just got my DCI today........and i wanna install it by myself but dont' wanna screw things up.......so.......just wanna do some research here....
can anyone send me the instruction cause the mail i got today only have the DCI but no instruction at all.........
i m a newbie in electronic......but i did installed the aftermarket HU by myself
just wonder is that easy to install the DCI when compare to install the HU
which one is easier???and how long does it take to install the DCI??
and which part do i have to concentrate the most??
thx for help!!!!!!!!
Old Jul 30, 2004 | 05:14 AM
steven975's Avatar
the DCI is easier.
plug the red wire to the +12V accessory (same as the red wire for the head unit). plug the black wire to ground (the same one as the head unit).
basically, for these wires, you'll have both the red and black shared with the head unit and the DCI.
the green and purple wires plug into the green and purple wires on the car side of the wiring harness. these 2 lead the the dash controls. the blue wire will plug into the "ATT" wire coming from the head unit. Not all head units have one (if not, tape it off and leave it alone). This is for the MUTE button.
Now, the Honda wiring harnesses you get at the stereo shops probably won't have the green and purple. When I got the DCI from Lucid, it came with a Honda harness with these wires. Did you get one with the DCI???
Basically, you will replace the wiring harness you already have for your head unit with the custom wiring harness you got with the DCI. Basically, you install the head unit with this new harness the same way you did before. Seriously, the DCI is a very easy install. don't forget to set the switches to your brand. If you have the Sony one, plug the jack into the back; it has no switches.
http://lucidauto.com/Merchant2/merchant.mv...y_Code=dciguide
Old Jul 30, 2004 | 08:13 PM
supman's Avatar
thx man
Old Aug 1, 2004 | 01:15 AM
Ludedude's Avatar
Administrator
That stuff might be outdated.
Check here for the latest instructions
http://www.baustnet.com/honda/mods/dci/ird...nstallation.htm
13darkknight
Jan 24, 2011 03:21 PM
nob
Sep 25, 2009 03:47 PM
RAIN H8R
Apr 22, 2008 12:23 PM
plutonium239
Sep 30, 2007 09:37 AM
Anrosphynx
Sep 2, 2004 03:26 PM
