Is it dificult to hook up the door speakers to an amp?
Old May 28, 2002 | 02:52 PM
murrays2k's Avatar
Default Is it dificult to hook up the door speakers to an amp?
I have a 4 channel amp and would like to run it to the door speakers is this a hard task?
Old May 28, 2002 | 04:04 PM
bbsilver's Avatar
Nope. The only tricky part is the harness boot between the door and the frame. You have to unattach both sides and probably (was a long time ago) disconnect the door harness from the main harness. Fish the lines through and reattach. That's it. Took about two lazy, beer-filled hours per door.
Old May 28, 2002 | 05:39 PM
murrays2k's Avatar
Thanks for the help
Old May 28, 2002 | 06:40 PM
PAS2KNut's Avatar
Here is a link to some useful information when it comes to fishing wire through the door.
https://www.s2ki.com/forums/showthread.php?...&threadid=47489
Good luck,
Jim
Old May 28, 2002 | 11:49 PM
Kwando's Avatar
It was easy for me. I used a coat hanger and fished it through the loom. After that I attached the speaker wire and make sure it would not come loose and just pulled the hanger back. The new 14 gauge wire was finished. Give that a try, it's easy one you have done it a few times. A coat hanger is a installers secret tool, you can use it to run wires every where.
Old May 29, 2002 | 04:45 AM
ByteIt's Avatar
[QUOTE]Originally posted by Kwando
[B]It was easy for me.
Old May 29, 2002 | 07:27 AM
lucid's Avatar
I left the grommet in place carefully slit a hole on the inside of the car to fish it through. I used a wire (not ground) from a 12-2 romex house wire about 2 feet long. Soldered the speaker wire to the end of the wire, slid heat shrink tubing over it and its all nice and neat. For lube, i used a KY because i feel its better for the rubber grommet. It slid through no problem. Only issue is fitting a 215lb/6'1" me down in the footwell to see what im doing.
Old May 29, 2002 | 01:37 PM
MacGyver's Avatar
Instead of a coathanger, use an industrial-sized Zip-Tie....they'll set you back about $1, and you significantly reduce your chances of poking through where you don't want to. You can pick them up at Home Depot, Lowes, etc. See my webpage...
Old May 29, 2002 | 04:54 PM
murrays2k's Avatar
Thanks for all of the help i am going to give it a try and i will take pic
Once i have the pics on my hard drive how do i put them on a post?
THanks
-RYan
Old May 29, 2002 | 07:04 PM
bbsilver's Avatar
[QUOTE]Originally posted by murrays2k
[B]Thanks for all of the help i am going to give it a try and i will take pic
