Dim fuel gauge light
Old Dec 6, 2008 | 05:56 PM
VKRider's Avatar
Default Dim fuel gauge light
this started 3 months ago on my 04 . my battery died on me , i got it recharged and started my car , i noticed my fuel gauge is dimmer than everything else on my gauge . I drove it for about a week and it lit brightly again like everything else on my gauge cluster . I then disconnected the battery to install some new dash lights and my fuel gauge went back to being dim . I got a new battery thinking that might be the problem ..but no luck ..anyone have a solution ?
Old Dec 6, 2008 | 08:06 PM
hunterD's Avatar
smack it.. than if that dosent work the bulb is goin bad..if you touch the bulb.. the acid on ur fingers will leave a hot spot on the bulb that will cut the bulb life shorter
Old Dec 7, 2008 | 11:26 PM
VKRider's Avatar
haha ..smacked it already ..didnt work
Old Dec 10, 2008 | 11:37 AM
MacGyver's Avatar
This is only true of high-intensity bulbs, like the xenons they put in the torchiere lamps from Wal-Mart (and your headlights). Regular incandescents don't get hot enough to suffer from this problem. The oils create a localized hot-spot, breaking the envelope.
Old Mar 10, 2009 | 05:50 PM
VKRider's Avatar
no one has an awnser to this ? are those leds to the fuel guage replaceble
Old Mar 10, 2009 | 06:05 PM
Stealth_SUX_'s Avatar
mine did the same thing.. a couple days later it fixed itself and havent had a problem since then, its been about a year..
I was thinking the same thing.. how weird that half of my cluster was dim and the other wasn't...
Old Mar 10, 2009 | 07:05 PM
VKRider's Avatar
yeh mine fixed itself once and then went back to being dim and has never gone back since..its annoying ..i dont want to have to go to the dealership and pay a grip of money just to get that stupid problem fixed
Old Mar 11, 2009 | 03:39 AM
MacGyver's Avatar
Take the bulb out and clean the contacts, make sure all of the wiring harnesses leading to the cluster are seated fully. A dimmed incandescent bulb is caused by low voltage... wiring/contacts is about the only thing that can cause that.
Old Mar 11, 2009 | 08:34 AM
VKRider's Avatar
ok ill see how that works thx !
Old Mar 19, 2009 | 09:20 PM
VKRider's Avatar
heres an update..it ended being being some dead bulbs back there and i got them replaced ..its brights again
garyg4761
Nov 19, 2017 03:02 AM
Jan
Mar 26, 2015 07:02 PM
StR8AwAy
Mar 12, 2012 06:47 PM
HPIracing
Jul 19, 2011 07:20 AM
MoogieBoogie
Nov 23, 2009 09:37 PM
