Light behind fuel gauge?
Old Mar 25, 2015 | 01:24 AM
Jan's Avatar
Jan
Default Light behind fuel gauge?
The lights behind my fuel gauge on the dash have failed??? Not being at all knowledgeable wondered if someone could tell me if it is a bulb? or electrical fault, i.e wiring come loose somewhere? Thanks
Old Mar 25, 2015 | 04:47 AM
zeroptzero's Avatar
Definitely a bulb.
If you are going to open up the cluster to replace the bulb you might as well get the entire set of bulbs as they will start failing one by one and you don't want to be going in there all the time. That's what I did when I upgraded my cluster.
Old Mar 26, 2015 | 07:02 PM
Utah S2K's Avatar
Bad bulb. Google Qube Engineering. He sells LED upgrades to the cluster. His documentation is the best out there. Poke around The "Support" drop down under "Documentation" and you can see how to access. It's not very hard to do if you follow his directions.
Utah
garyg4761
Nov 19, 2017 03:02 AM
themighty7
Sep 20, 2011 01:11 AM
themighty7
Sep 17, 2011 11:56 AM
HPIracing
Jul 19, 2011 07:20 AM
VKRider
Mar 19, 2009 09:20 PM
