Drivers Window switch
Old Aug 7, 2005 | 09:27 AM
911turtle's Avatar
Arrow Drivers Window switch
This is the second time this has happened;
The switch for the auto window control has stopped working. The first time, i took it to Honda's & they "re-set it".
I don't want to hassle them for a small thing like this, but since the drivers window won't come down when the roof switch is operated, i need to get it sorted. Otherwise, the window ges up & down as long as you keep you're finger on the switch.
Has anyone come across this before?
Thanks in advance
Old Aug 7, 2005 | 10:33 AM
xviper's Avatar
There is a TSB on this for earlier cars. I'm surprised given that you have an '04 that this has not been fixed with the new window regulator right from the factory. Looks like you'll need a new regulator on warranty.
Old Aug 8, 2005 | 07:58 AM
DWynne's Avatar
I think there is a no parts fix for this. I will try to post a link if I can get the search to work. You have to "reset" the power windows, I think. Most likely you or a passenger hit one of the window switches while you were operating the top.
Seems like it involves running the windows all the way up and down a few times....
Dennis
Old Aug 8, 2005 | 08:10 AM
DWynne's Avatar
See the thread here:
https://www.s2ki.com/forums/index.ph...pic=131795&hl=
Dennis
Old Aug 8, 2005 | 08:17 AM
xviper's Avatar
Dennis
This is not always a "fix". It's the first thing the dealer will do and then send you home. You can do this yourself:
-with car running,
-lower window with switch and continue to hold the switch till you hear a click.
-raise window with switch and continue to hold the switch till you hear a click.
-Shut ignition off.
When you start the car again, this should have reset the window limits and the window "should" work (for a while, maybe not).
This is when you must do the TSB to have a new window reg put in. If you do not desire to have your door dismantled, you have another option. Get an "Autoloc" devices and install it in the door. This costs about 40 to 50 bucks and it will not only solve your problems but will also give you auto UP and DOWN. I have it and it's just great.
Old Aug 8, 2005 | 12:04 PM
PJK3's Avatar
i'm on my 3rd or 4th regulator now....
it is covered under warranty (OEM and Hondacare) but i'm not sure how this will apply across the pond.
the 'fix' only worked for me for a little while on my older regulators, and progressively worked for less and less time. and it essentially didn't work for me at all on the newest TSB regulator. i'm on my 2nd new upgraded TSB recommended regulator. so far, it's been holding out quite nicely. this is a known issue -- don't let them do the 'quick fix' and tell you it's ok.... chances are it will come back.
Old Aug 8, 2005 | 12:52 PM
911turtle's Avatar
Thanks guys for all the tips.
The window is now functioning properly
I checked the Honda part #'s between an 04 & 02 model switch regulator; they are still using the same unit!!
Thanks
Old Aug 8, 2005 | 01:30 PM
xviper's Avatar
Thanks
Not necessarily. They most likely changed the part but kept the same part number. It's just like if you ordered oiljet bolts for an '00, you will use the same part number, but you will NOT get the old bolts.
elkdaddy
Feb 22, 2018 06:10 PM
mikdys
May 9, 2008 08:43 AM
Teh Legacy
Apr 13, 2008 05:41 PM
theSILVERone
Oct 3, 2007 09:11 PM
S2Kinside
Jul 20, 2006 07:20 AM
