DVD in rearview mirror?
Old Nov 27, 2003 | 09:07 PM
J.T's Avatar
J.T
Default DVD in rearview mirror?
I know some of you won't see the point of having DVD in the rearveiw mirror but for what its worth I won't be driving and watching at the same time....
So my question I think is sorta simple.
Could I use a DVD/CD/tuner headunit and hook it up to a SAVV Rearview mirror monitor and be done? It seems like that would be to easy? Am I missing something?
If it is that easy, do you have any recommendations for the headunit?
Thanks,
Old Nov 28, 2003 | 09:54 AM
NFRs2000NYC's Avatar
Yes you can. gets you the pimp points too....
Its easy, just wiring would be tricky (hiding the wire off the windshield)
Panasonic, Alpine make great single DIN mp3 head units.
Old Nov 28, 2003 | 10:48 PM
J.T's Avatar
J.T
cool. ok so Im looking at these 2 recievers and would like you opinions on them. Which is better?
Panasonic CQ-DVR592U
and/or
Pioneer DVH-P5000MP
Also on Crutchfield.com it says I will need to modify and mounting bracket for either of these to fit. What does that mean? I believe the are both 1 bin recievers.
Thanks
Old Nov 28, 2003 | 11:53 PM
you dont have to modify anything.......go for it.......they are both great decks....
I think the panasonic comes with a built in center channel......
both are great.....get the cheaper one.....
Old Nov 29, 2003 | 02:17 PM
mikes2k's Avatar
FYI: Have you seen the SAVV monitors in person? the resolution is not the same quality that a stand alone monitor will give you.
Old Dec 3, 2003 | 02:48 PM
rworne's Avatar
I've seen a SAAV rearview mirror monitor. They are HUGE, especially in this car. Bear that in mind.
Doesn't compare at all to say an Alpine monitor with RGB inputs. But it is acceptable for video feeds.
Old Dec 10, 2003 | 05:32 PM
jahnke's Avatar
Its only $299 too...thats not a bad deal and you dont have to cut the dash.
Old Dec 10, 2003 | 08:43 PM
rworne's Avatar
Yes, but imagine a mirror with approximately 4x the surface area of the stock mirror. You also need to remount the mirror mount about 1/2" to 1" lower or the SAAV hits the domelights.
Check this thread out:
http://forums.s2ki.com/forums/showthread.p...ght=SAAV+mirror
Moddiction
May 2, 2009 01:35 PM
G2k
Nov 22, 2006 03:53 PM
Chubbikin
Sep 6, 2004 08:46 PM
S2Kevin
Feb 10, 2004 06:53 PM
NJSY2K!
Feb 20, 2003 10:36 PM
