DYNAMAT
Old Feb 17, 2006 | 12:03 AM
atxs2kboi's Avatar
Default DYNAMAT
Has any here actually dynamt their trunk. How hard or easy is it to do?
Old Feb 17, 2006 | 04:36 AM
PTHermes's Avatar
As a previous car audio installer. The biggest suggestion I would have is to splurge and go with Dynamat extreme. The adhesive sticks a lot better than regular dynamat and also pick up a roller of some sort of hard material to really press it down with.
Also before laying any dynamat, take note of where all the holes for the trunklining push buttons are (plastic clips), and cut out a generous hole in the dynamat for them. It is much easier to do so ahead of time then trying to peel it back off in that area and ending up with a sticky mess.
Hope this helps.
Old Feb 17, 2006 | 05:54 AM
S2KinVA's Avatar
Well worth the $$$ DO IT!
Old Feb 17, 2006 | 06:13 AM
Pulse's Avatar
It's not to hard, is a bit time consuming though and you'll probably have some pain in your lower back when done.
Is worth it though. I've got 90% of my trunk done. When I get more time I'm going to finish the trunk and start on the cabin.
Old Feb 17, 2006 | 06:32 AM
darkknight1999's Avatar
Yes you should do it! Its one of those things that its worth the money everytime.
Like mentioned above keep track of the mounting holes... however I disagree with cutting them out before hand though. I've always mark their location with a marker and then ueing a philips head screwdriver I push though the whole. Doing it this way does two things:
1. Covers eveything as much as possible, and therefore you have less waste.
2. After you pull those push clips out they are now wore some,... by having the Dynamat go all the way to the edge of the hole helps to seal them up making the clip sit firmly in the hole again.
BTW I can get the Dynamat for you.
If we have enough interest I'll do a Groupbuy for it.
Old Feb 17, 2006 | 06:59 AM
wu01ok's Avatar
Hey everybody have pics of dynamat install in there trunk?
Old Feb 17, 2006 | 07:03 AM
I've since put more in after I took these pictures but you get the idea.
Old Feb 17, 2006 | 07:49 AM
wu01ok's Avatar
Looks nice. Hey do you not have to cover the holes in the truck in the thrid hole? Anything was that when it was ratteing I press my hand on the truck to tighten it help alot. But what can I do to tighten the truck when it is close or will I not have to do this when I dyanmat the truck?
Old Feb 17, 2006 | 07:54 AM
atxs2kboi's Avatar
How big of an improvement will I notice? Will the truck still rattle little bit? Is the Extreme trunk kit enough to do the job?
P.S: I am getting dynamat extreme trunk kit installed monday by a local audio shop. I already had the extreme door kit install when the did my system last week.
Old Feb 17, 2006 | 08:33 AM
Umm... I'm going to try and decode that...
The first question I have no clue what you meant...
The next one... dude, just damn man.. just damn
And the third one... umm... I might actually understand that one... maybe.
But if you back the rubber stoppers back out it will left it up and tighten up on the latch.
