dynamat
Old Feb 15, 2007 | 10:36 AM
  #21
S2000GT's Avatar
you can get the stock linings back on if you keep it to 2 or 3 layers
Old Feb 15, 2007 | 10:38 AM
  #22
DDuds2k's Avatar
Is 2 layers suffice?
Old Apr 9, 2007 | 10:15 PM
  #23
Silvers808's Avatar
Originally Posted by S2000GT,Feb 13 2007, 06:32 PM
to be honest, the extra weight I added with the soundproofing is negligible to the extra weight in hauling in the trunk with the added audio.
And with everything in, the car handles amazing still, but then i do also have a lot of suspension and chassis mods.
is this carbon fiber cloth? or did u actually use a resin too
Old Apr 9, 2007 | 10:30 PM
  #24
darkknight1999's Avatar
Well you can see the reflection from the resin can you Its actual carbon.
Old Apr 9, 2007 | 10:46 PM
  #25
Romeez's Avatar
[QUOTE=S2000GT,Feb 13 2007, 08:32 PM]to be honest, the extra weight I added with the soundproofing is negligible to the extra weight in hauling in the trunk with the added audio.
Old Apr 10, 2007 | 03:34 AM
  #26
S2000GT's Avatar
Yes, this is REAL carbon fiber composite - no cheap lookalike cloth here
I decided not to use the resin in there - I wanted it raw. The reflection you see are from the plexi panels I made so that I can actually transport things in the trunk. They come out for shows. The CF weave is so fragile that putting anything on it will cause it to move around and misweave.
It looks great, but is TOTALLY impracticle!
Old Apr 10, 2007 | 03:35 AM
  #27
S2000GT's Avatar
[QUOTE=Romeez,Apr 10 2007, 01:46 AM] My favorite s2k trunk ever!
Old Apr 10, 2007 | 03:35 PM
  #28
Silvers808's Avatar
i figured it was the real deal....it really looked like there was no resin. looks very good =)
did you think about using 3M spray adhesive to bond it to the stock panneling?
Old Apr 10, 2007 | 04:25 PM
  #29
S2000GT's Avatar
thats what i did. It holds the bottom of the strands, but the tops are still free to move around. I could cover it all in resin to fix it, but then that just defeats the object of what i wanted to do in the first place.
Old Aug 1, 2007 | 05:16 PM
  #30
starbai's Avatar
Originally Posted by WTFWASTHAT?,Feb 13 2007, 11:50 AM
Great job!
Did you remove any of that factory jute stuff around the fuel tank or did you dynamat around it?
being the sick arse I am...I bought a db meter to I can test the sound levels before and after.
how much material did it take to do all that?
I'm looing at 50sq ft on e-bay.
how much do you think u used/needed?
