E-Manage ignition wiring Problem!help!
I have just connected my e-manage in my s2k MY2003 with ignition and injector harnesses.
I 've followed the wiring diagram that i have found in this forum,
Ifolowed as the instructions of the v-afc for the injectors +vtec controller the car DIDNT WORK WEL and i am desperate trying to find a solution.
the s2000 sounds like working with the wrong timing.
i have put
1 to 1
2 to 2
3 to 3
4 to 4
i am using 8c for pressure (code)
jp1 1-2
jp2 1-2
jp3 2-3
jp4 1-2
jp5 off
jp6 off
jp7 off
PLEASE HELP ME WITH A WIRING DIAGRAM WITH THE IGNITION HELP!
i have put
1 to 1
2 to 2
3 to 3
4 to 4
jp1 1-2
jp2 1-2
jp3 2-3
jp4 1-2
jp5 off
jp6 off
jp7 off
yea, i had the same problem as well and i went down to greddy and figured out that the ignition harness does not work with it so you have to take it off but leave the injector harness on and it should start right up with no problems like mine did.
Why cant I find a Frog harness for my emanage? Do they all require you to send them your sub harness? I ahvent looked at the wiring yet, but im guessing you guys are talking about wiring up with out the harness and adding the injector and ignition wires.
Virus
Oct 28, 2003 09:03 PM
