ELECTRICAL SHORT
Old Mar 29, 2010 | 08:40 PM
vietthuqstyle's Avatar
Default ELECTRICAL SHORT
ok guys...im having a problem with my radio turning off and on intermitently...weird thing is...it turns off when i press the mute button and turns back on when i unmute it...also my dome lights doesn't work consistently neither...ive noticed this is all only in cold weather only...i think its a short or something but not sure...any help would be appreciated..my car is an 05 with 30xxx miles...
Old Mar 30, 2010 | 12:27 PM
UPDATE!!! i think i fixed it...read a little bit more on s2ki.com and replaced the accessory power relay...there are actually two relays (part # 39794-s10-003) under the driver side dash, right of the steering column...i replaced both (will cost under $50 total for both)...now i don't have any intermitent play of the radio nor mute button...the dome lights however still seems not to work consistently..
Old Mar 31, 2010 | 05:07 PM
FromaDB2toanAP1's Avatar
hey does it sound like my problem?
Hey guys, ever since I purchased my s2k two years ago, I've been having electrical problems. Could this be it? My accessory power (cig lighter) doesn't work (charge), but when I do plug something in it, it shuts off my stereo. Also, from time to time, my mute button turns on and my whole stereo shuts off so I have to turn it off and wait a few seconds or even minutes. Also, the stereo shuts off when I use the mirror adjusters..
Old Mar 31, 2010 | 05:08 PM
is the part number the same for both relays?
Old Apr 1, 2010 | 10:31 AM
sounds like the same symptoms that i was having, i changed out the two relays and now everything is fine....and yes the part number is the same for both relays (39794-s10-003)
tua40278
Apr 21, 2010 05:42 AM
hondanc7
Aug 9, 2009 03:19 PM
mhdelano
May 9, 2009 09:14 PM
p0pe
Nov 23, 2005 05:44 AM
s-duces
Jul 4, 2003 02:45 AM
