EU Start Button, Radio, and A/C Controls & Jumper Harness
Old May 28, 2021 | 10:25 AM
rag3's Avatar
Default EU Start Button, Radio, and A/C Controls & DIY Jumper Harness
I was always annoyed that the Start Button was never on the same side as the Ignition and Key. So I made a plug and play harness that would make the European controls work on the US S2000.
Along with the European radio and a/c controls, I bought an additional wiring harness and US radio, start, and a/c controls so that I would still have the option of going back to stock in the event I change my mind.
I measured that the harness would have to be about 22 inches long to have it plugged in with some wiggle room to position the harness so that everything fits in.
I used a Dremel to cut around the female connectors of the controls, unsoldered the pins, and Dremel the motherboards to use as a support backing on the female connector. (I forgot to take a picture of the radio female connector)
Then I would remove the pins from the connectors and strip a wire from the spare harness and bind it to the connector.
Then I would use 22-18 Gauge Heat-Shrink Solder-Loaded Crimp-On Butt Connectors to connect the pins and measured wire on the harness.
Then I the female ends into the male connectors in my dash and after they were secured pinned in the wiring harness on the corresponding pins.
After testing that the harness worked I taped everything up in electrical tape and covered it in a wire loom.
Then I positioned everything so that it made the cluster bezel fit in flush and resembled everything back together.
https://drive.google.com/file/d/1JGi...w?usp=drivesdk
Old May 29, 2021 | 08:11 AM
Kyle's Avatar
Fantastic work! First time I've ever seen this.
Old May 30, 2021 | 08:11 AM
Chuck S's Avatar
Looks very nice.
I always thought the European cars had the same dash we have in North America -- both are left-hand-drive arrangements.
-- Chuck
Old Jun 1, 2021 | 08:39 AM
Sobe_Death's Avatar
Originally Posted by Chuck S
Looks very nice.
-- Chuck
UK used to be EU, but they still have the RHD arrangement.
Rewire
Jan 30, 2021 02:31 PM
CRazn
Sep 22, 2013 07:27 PM
Wydget
May 25, 2010 07:01 PM
HMSmikesS2K
Aug 30, 2008 07:39 AM
24s2k7
Feb 24, 2006 03:17 PM
