Failing battery of fuse issue, you be the judge!
Electricians, handy men, electrical engineers, fellow s owners! I am experiencing electrical symptoms which has me currently stumped as to what the issue is. I am not sure if the battery's going out or if it's a fuse/relay related issue. I have checked all of the mini fuses beneath the steering wheel assembly and all seem to be intact (visually). Next I am going to troubleshoot the battery to make sure there's still juice. I believe it's the original battery and I am at 69k miles. Is there anywhere/anything else I should check other than the battery?
Symptoms for what does NOT work:
- Keyless entry does not work
- Trunk does not open, but you can hear a clicking in the rear (weird)
- Gauge cluster does not work
- Horn is very very very very faint
- Hazard lights do not illuminate but has a buzzing sound when activated
- Headlights do not illuminate but also has a buzzing sound when activated
- Dome lights do not work
Symptoms for what is working:
- Chime works (when you put the key in and the door's open)
I was gonna say I have the similar issue. I Changed the fuse one more time and was going to drive around the block and my friend notice the lights turn off as soon as I accelerated... You might as well get some batteries or relays' info from blmall.com. Good luck.
Sky1air
Jan 19, 2016 05:16 AM
TheDonEffect
Aug 13, 2008 10:40 PM
