Fitting F20C into BMW 2002
Hi,
I am new to this forum. I am currently putting a f20c engine into a bmw 2002. It has been done a few times before so you're probably bored of these questions.
You can see my build thread here.
http://www.02forum.co.uk/viewtopic.php?f=11&t=9158
I have got the full s2000 electronics manual but it is a LHD version, i'm hoping the LHD and RHD wiring aren't too different.
I am using the s2000 engine loom, interior loom, fuel pump, column, gauges, sensors, some switches and fuse/relay boxes.
I have gone through the looms that i have got and have labelled up all the plugs that i can from the electronics manual, but i now have a few left over plugs which i hope you can help me with.
Does anyone know what these three plugs are as i can't find them in the manual
Does anyone know what large wires screw into this fuse box. I'm assuming the large white one goes on one side but i'm not sure which side, what goes on the other side?
Where does this other white wire go?
Thanks in advance for the help.
Cheers,
Aaron
Cheers,
Aaron
Hi, I've plugged up on to the battery now and as soon as I put the battery terminal on the starter motor starts to turn over. I've took out fuse 52 and the power to the starter solenoid is removed. I dont see how the starter solenoid and fuse 52 are linked as its not shown in the electrical diagrams. The second issue is as soon as I put the battery on the gauges come on. If I pull out fuse 25 the gauges come on with the second click of the key. Again I don't know how fuse 25 is affecting gauges to come on without the key in :/
Any help is appreciated
thanks
Aaron
thanks
Aaron
Curated Content Editor
03-15-2019 07:50 AM
