Front Speakers Fitting Questions.
Old Nov 27, 2010 | 07:30 AM
MrYellow66's Avatar
Default Front Speakers Fitting Questions.
Hello All. I am determined to upgrade my '05 S2k stereo system now that I have time and money to work on this project. I currently have an Alpine HU with many pre-outs, so I am planning to get a 4-channel amp to support a single sub and a pair of 6.5" component.
I've been researching on this forum for over a week now, and read many threads on how to custom fit 6.5" speakers. One idea is to make your own 3/4" MDF baffle. Another idea is to purchase 1/2" Metra spacer. And another idea is to cut out the back end of the stock speaker basket. All ideas will not be a problem for me, but I am still unclear/skeptical on how a 6.5" speakers with a 2.54" top mounting depth will fit.
Wouldn't the speakers be rubbing against the door panel if a 3/4 " MDF baffle or 1/2" spacer be used?
Wouldn't the speaker magnet on a 2.54" top mounting depth speaker be touching the window if I decide cut the back of the stock speaker basket?
I am planning to get a set of Alpine SPX-17PRO or JL Audio C5-650, but that all depends on what will fit.
Sorry for posting on a topic that's been talked about over and over, but I havent seen any recent posting of current components such as Alpine SPX-17PRO or JL Audio C5-650, or anyone confirming that these components will fit in their '05 S2K.
Any help from you pros will be appreciated.
Old Nov 27, 2010 | 08:34 AM
06S2k07Si's Avatar
I would suggest making your own extension baffle. If you do, be sure to water proof it/paint it to prevent water from damaging it over time. Once you open up the door you can measure how much space you will have/need etc.
Some good info here:
https://www.s2ki.com/forums/index.ph...&f=26&t=269226
Brian
Old Nov 27, 2010 | 09:06 AM
MrYellow66's Avatar
Brian
Thanks Brian. That is a really good write up on "How to make MDF speaker brackets" by PAS2KNut.
So there's no problem with the speakers rubbing against the door panel using 3/4" MDF brackets?
Also, does anyone have JL Audio C5-650 or Alpine SPX-17PRO in their S2K? How do they sound? Will the JL or Alpine tweeters fit inside the stock tweeter location?
I havent kept up with car stereo technology for a while now. Used to love MB Quarts but since they got bought out by Maxxsonics, seems like MB Quarts haven't improved on their technology.
Old Nov 27, 2010 | 06:57 PM
06S2k07Si's Avatar
"So there's no problem with the speakers rubbing against the door panel using 3/4" MDF brackets?"
This will depend on the speaker that you choose and how large the outer diameter/shape that you make the baffles. Each speaker's frame is a bit different.
"Also, does anyone have JL Audio C5-650 or Alpine SPX-17PRO in their S2K? How do they sound? Will the JL or Alpine tweeters fit inside the stock tweeter location?"
I have heard the JL's...they are nice (I have not heard the Alpine's). As for the tweeters...most can be made to fit. I would like to HIGHLY suggest these (don't know your budget) as they are fabulous! These CAN be found for less than $475:
http://caraudiomag.com/articles/hertz-mlk-...nent-set-review
Brian
Old Nov 28, 2010 | 02:42 PM
MrYellow66's Avatar
Brian
Wow! Best rated 6.5" components on Car Audio Mag. Those are nice.
I did some researching and found the top mounting depth for Hertz MLK is 79.5mm or 3.14". I don think it's going to fit in the S2k door with that depth.
If they fit and I could find them for $500, I will buy for sure.
Please tell me you have a set of those in your S2K.
Old Nov 28, 2010 | 04:57 PM
06S2k07Si's Avatar
Currently...no, but I do plan to this coming spring/summer. If you have had the opportunity to hear these you would do what ever it took to get these in there! I've installed a set recently in a friends Mazda 3.
Want some?...I can get em for you! No BS..and brand new from my local shop.
Let me know.
Brian
Old Nov 29, 2010 | 08:59 PM
MrYellow66's Avatar
Let me know.
Brian
Thanks but no thanks. I am still debating on $300 set or $500 sets. If I decide on $500 set, then I am sure I'll be able to demo Hertz MLK somewhere in my hood (South Cali). But thanks for the suggestion, it opened my mind and ears about audiophile components. I'll keep you posted on what I'll end up with. Thanks Brian.
Old Nov 30, 2010 | 02:52 AM
06S2k07Si's Avatar
You're very welcome!
Old Nov 30, 2010 | 05:16 AM
dsms2k's Avatar
i have the alpine type r's stats show Top-mount depth: 2-5/16"
i cut my basket. seems to fit fine and isnt touching. there is a liner there and my car will never see bad weather.
Elysian
Dec 22, 2013 06:34 AM
GreenmanS2000
Sep 5, 2011 10:50 PM
stena
Feb 20, 2004 03:31 AM
usace
Nov 17, 2003 11:09 AM
sarama711
Jul 24, 2003 05:31 AM
