GPS Help Needed!
Old Jul 23, 2009 | 09:01 AM
conradadams's Avatar
Default GPS Help Needed!
New user here - Im installing GPS on my 2007 S2000 and the instructions are telling me I need to hook up the GPS to the "VSS (Digital or Analog 0V - 3V)' - - - To the vehicle speed pulse line"
Which wire is this? Most info I have found is on the AP1s and there were changes on the DBW AP2s.
I have the factory service manual, but this doesn't say anything about VSS other then how to trouble shoot it (under the Body Electrical section).
Please help, car torn apart!!!
Old Jul 23, 2009 | 10:29 AM
Ok... so I searched the forums again and found this:
http://www.modifry.com/products/yj/Yellow%...202006-2007.pdf
It's an install guide for a Modifry Yellowjacket which makes you tap the VSS (blue/white) wire.
I tapped this wire, but for some reason the GPS shows me as going 8MPH even when stopped.
Did I tap the wrong wire? Im using wire to tap it that's a tad bigger gauge - could this be the problem?
So close, yet so far.
Please help!
Old Jul 23, 2009 | 11:50 AM
Penforhire's Avatar
I thought the VSS line, in the cabin, was found under the dash, behind the passenger side pockets? That's were I tapped it for the Modifry DCI speed sensitive volume (mine works).
Old Jul 23, 2009 | 12:02 PM
[QUOTE=Penforhire,Jul 23 2009, 11:50 AM] I thought the VSS line, in the cabin, was found under the dash, behind the passenger side pockets?
Old Jul 24, 2009 | 04:35 AM
So I noticed something funny about my GPS Speed Readout... The MPH in the GPS is directly attached to the RPMs. As RPMs go up (when stopped) the MPH in the GPS goes up.
Does the VSS putout an RPM signal on newer DBWs? Any other ideas?
Old Jul 24, 2009 | 02:59 PM
Penforhire's Avatar
Yep, your link shows the speed line I used. There is quite a mess-o-harness back in there. Tons of small wires.
Old Jul 25, 2009 | 09:12 AM
DFWs2k's Avatar
it does that on all s2000's, i think
there's a black/white wire in the passenger area of the cabin, i believe it's white w/ a black stripe, try that one (if you need more instructions on finding it, search for "top down while driving")
Old Jul 25, 2009 | 01:43 PM
Yep... I hit the black/white wire in the convertible top module and everything is 100%.
Thanks S2Ki!
hyper-rev
Dec 21, 2011 12:56 AM
lecter255
Oct 5, 2009 03:26 PM
mikdys
Dec 31, 2004 05:32 AM
owenxguo
Mar 30, 2004 07:46 AM
S2WOOOW
Dec 19, 2002 01:39 PM
