Help with Modifry's "rev beeper"....
one? See:
https://www.s2ki.com/forums/index.php?showt...0&#entry4860097
Even if you haven't have you any idea how I can locate and verify which wire is the tacho' feed wire?
Any construtive comments welcome (I have the workshop manual on CD but I'm damned if I can understand the information it contains in terms of wire locations - maybe a lesson here is all that I need
I think the one you're looking for is the black and white striped wire. Same one that's used for the HU auto volume control.
Try Lucid's sitehere.
That's got the install instructions and shows the wire.
BTW If I ever get the little devil working I'll post some pictures of the hook-up that works (could save somebody else in the UK a lot of grief!)
EDIT:
I don't think that's the one - the lucid site shows the vehicle speed sensor wire location and its engine speed I need but thanks for the idea anyway.
I don't know if this will help but this PDF link show's which is the rev and speed pin at the ecu.
http://www.apexi-usa.com/productdocumentat...ringDiagram.pdf
Page 31 of 47, diagram H8-a
EDIT: Success (with the shop manual so far) a chap in Australia has fitted one of these on a RHD and pointed out that the Yanks have differently wired stand-alone connectors due to the cruise control that is fitted. He has wired his feed directly onto the ECM connector (and he pointed out the same info as you to help me find this). Funny thing is, when I stopped looking in the shop manual for a stand-alone connector with this feed and looked at the ECM connector instead I went straight to it (ECM connector A, terminal 19, blue wire). Thanks again for pointing me in the right direction (when - not if now
- I get this sucker working I'll post some pictures of the hook-up to help out anyone else with a RHD that buys one of these gizmo's).
I knew saving all those PDF links would come in handy one day for something
I got one of these little chav things with shift lights built in
http://www.gtechpro.com/rr.html
It seems to work quite well, Hrmmm flashing bright led lights
Thanks for your help too I've sorted things out now see:
https://www.s2ki.com/forums/index.ph...&f=25&t=258426
