GPS Installation question...
Old Mar 8, 2007 | 03:31 PM
preilly44's Avatar
Default GPS Installation question...
Hello all,
I just received my JVC NX-5000 GPS and I have an installation question
Old Mar 8, 2007 | 03:41 PM
sean2sean's Avatar
it should. in my avic n1 i connected the speed sensor. just make sure you ground the parking brake cable.
if you dont connect the speed sensor, it may throw off your reading... especially when your under a bridge, or parking complex
Old Mar 9, 2007 | 10:58 AM
preilly44's Avatar
Thanks for your help, now I'm having another issue. The GPS continuously calibrates. The manual says to drive around at over 25mph which I did (I drove 30 minutes to work at 70mph) and it should finish calibrating in five minutes. I have confirmed that the antenna cable is connected and it is receiving a satellite signal from 4 satellites (100% and 3 at 75%). I have also confirmed the speedometer cable is working because the unit has a speed sensor diagnostic....but the GPS always shows the speed as 0mph.
I grounded the parking brake cable so it is always showing up as if it is on. That shouldn't affect the unit from calibrating though, right? Any help or advice would be appreciated. This was my first GPS install.
Patrick
chrisyi1
Nov 5, 2007 03:53 PM
jerome baker
May 22, 2007 04:28 PM
darkknight1999
Mar 18, 2005 07:52 AM
Colt
Aug 1, 2004 07:38 PM
TIMELESS
Feb 10, 2003 09:48 AM
