H-Bus to C-Bus conversion
Old Jul 2, 2009 | 02:04 PM
bungholio's Avatar
Default H-Bus to C-Bus conversion
Alright you electronics junkies, I need your help with some wiring conversion.
I wanted to utilize the AUX/CD 14 pin changer in the rear of the radio. My original was a 14 Pin H-Bus connector. The new radio is a 14 Pin C-Bus connector.
Has anyone done this conversion that could help me. This is what I came up with.
Existing Radio AP1 2002 H-Bus Rear Connector Pinout:
1 - Audio Common
2 - CD Rch Imput
3 - No Connection
4 - Bus Out
5 - Accessory Power
6 - Illumination Shide
7 - Illumination
8 - Shide Ground
9 - CD Lch Imput
10 - Bus Shide
11 - Bus Ground
12 - Ground
13 - Power Supply +B
14 - Illumination Cont
New Radio C-Bus Rear Connector Pinout:
01 - 12V constant
02 - accessory
03 - ground
04 - ground
05 - Right Channel (+)
06 - Left Channel (+)
07 - 12V constant
08 - illumination (+)
09 - BUS (+)
10 - BUS (-)
11 - ground
12 - illumination (-)
13 - Right Channel (-)
14 - Left Channel (-)
Basically, What in C-Bus goes into the H-Bus plug. The above is almost foreign language to me so if anyone can help it would be great.
Thanks in Advance.
Old Jul 2, 2009 | 06:11 PM
txjeepn's Avatar
It looks like the H bus is digital and the C bus is analog. Its not going to work no way no how. Unless you find some sort of digital to analog converter that is made by alpine for this application.
Simplegreenvr6
Jun 14, 2017 02:07 PM
corders955
Feb 8, 2010 11:32 AM
Dr Col
Aug 12, 2007 11:39 AM
wet_poo
Sep 21, 2005 03:21 PM
x mj x s2000
Aug 27, 2005 08:00 AM
