Hardwiring Radar Detector
Old Mar 9, 2008 | 08:29 PM
Nate4635's Avatar
Default Hardwiring Radar Detector
I am hardwired for a V1 detector (previous owner). I just got a Beltronics 955, and it doesnt work with the V1 wiring....does anyone know what is different between the 2? It would be sweet to use that...and i guess i was under the assumption that i could, but apparently its different?
Any ideas?
Nate
Old Mar 10, 2008 | 05:10 AM
Will's Avatar
as long as there is no voltage regulator built into the wiring for the V1, then you could just switch the plugs... cut off the existing plug, then add a telephone style plug. A pack of plugs and a crimp tool from Home Depot will run you less than $10.
Old Mar 10, 2008 | 05:23 AM
imdarkrider's Avatar
Ummm I hope you didnt' plug the 955 into that... the ground and power are reversed in the plug and you possibly could have blown a resistor.
Old Mar 10, 2008 | 04:30 PM
Nate4635's Avatar
Will - The beltronics has the same plug as the V1, so if i need to make any changes, sounds like its just wiring.
imdarkrider - I did plug it to that.. I dont see how it would blow a resistor as resistors dont care about polarity? However.....if the ground and power are reversed...seems like an easy enough fix.
Nate
9000rpmftw
Upstate New York Classifieds
Jul 14, 2015 02:37 PM
S2K 4 ME
Oct 25, 2009 09:58 AM
tcjensen
Aug 27, 2007 10:08 PM
05011994
Apr 10, 2006 09:56 AM
